CL: Hifonics Brutus Amp - Protect Help
Old 08-24-2011, 12:00 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,425 Likes on 3,031 Posts
I have a Brutus amp, and my car sat in the sun on the hottest day we had this year. When I fired up the car, the amp went into protect mode, I'm assuming from overheating. I yanked the fuses out, and killed the circuit breaker that powers the amp, however when I turned it back on, it goes to red protect. Now it still powers on, and the LED's on the top light up. Just wondering if one of our amp gurus knew anything about this and knows how to reset it? I swapped it out for a spare amp, but would really like to get this working again if possible. Thanks guys.
Old 08-24-2011, 12:10 PM
fourthmeal's Avatar
Amps don't really have resets like that. Power off, power on, and if it is still dead, then you have a new paperweight.
But always bench-test the amp outright first, this will eliminate any shorted RCA's or some other issue not visible in the install right away. If it passes the bench test, then you know something's up w/ your wiring. If it doesn't pass, then it either goes to service or the trash.
Old 08-24-2011, 02:22 PM
3.7L Nitrous Breathing CL
richardparker's Avatar
Only two differnt occassions my Hifonics amps went into red protect was:
When I was running it at .5 ohms slaming or when a sub shitted the bed.
And either time they still worked fine after letting it cool or disconecting the bad sub.
The amp sounds like it's done.
I've beat all 3 brutus's I've owned and never had one quit.
Old 08-24-2011, 03:37 PM
fourthmeal's Avatar
Exactly right, always bench test without any other part that the system is comprised of, to eliminate them from contention.
Old 09-08-2011, 08:28 AM
(Mid-Atlantic)
Already had this amp rebuilt once, as my buddy that I got it from blew the bridging chip. Tried hooking it up in my friend's yukon and got nothing. Looks like it's time for another rebuild
Old 09-08-2011, 12:44 PM
eggyhustles's Avatar
Replace it with something better?
Old 09-08-2011, 02:48 PM
(Mid-Atlantic)
I'm already running on a backup amp, going to find out what the rebuild cost will be and go from there. I've already been screwed over on a few amps, so I try to stick with what works
Old 10-02-2011, 09:25 AM
vtec kicked in yo
antonio3rd's Avatar
what do you suggest better? ive ran nothing but hifonics and never had problems... thy usually occur when the electrical isnt enough ..witch in CL's we have very bad aux power lol
i would suggest an extra battery (50ah+) and that should help from frying your next one. im doing 2 75 a with a yellowtop starter with a brz2400. but im a competitor lol . daily setups only take a batt or less... LMK how it goes and if you need deadining hit me up!
Old 10-02-2011, 01:42 PM
Jimmay's Avatar
Youre a competitor and youre asking whats better than Hifonics? What equipment do you use?
Old 10-02-2011, 01:43 PM
vtec kicked in yo
antonio3rd's Avatar
maxxsonics and sundown . are my main choices . both reliable and do over rated
Old 10-02-2011, 06:40 PM
Jimmay's Avatar
I agree with you on that. Sundown= teh sex
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: CL: Hifonics Brutus Amp - Protect Help
