Help with switch
Help with switch
hey guys im trying to wire my neon tubes to a switch... however it is an old switch and i forgot which wires go to which port... i know that the middle one is ground if im not mistaken... but do i even need to ground the switch if i already ground each neon tube??? one of the ports on the switch has 6A/3A and the other side is AC... can someone tell me which side the power from the car goes to and which side the neon tubes go to.. i will attemp to draw the switch... after finishing i just realized the thread pushes all spaces together... so please use ur imagination and spread out the lines...
____________/___________ <~~ Top of switch
|_______________________| <~~ Bottom of switch..
6A 125V AC
3A 250V AC
am i correct when i say that the middle is the ground and the current from the car comes in at AC and travels to the neon tubes that are on 6A/3A...
thanks in advanced
6A 125V AC
3A 250V AC
thanks in advanced
Biggie_B
02-26-2017 11:14 AM
xsilverhawkx
09-28-2015 06:51 PM
