HELP: Stuck!
HELP: Stuck!
Hey guys, need some help... i m trying to install the oem mp3 player..
and it wants me to "gently pry up the center console panal to release
the eight clip"
i m totally suck
how do i do that?? i pull on it, it won't come up...
i tired to use a flathead to pry it out (using a cloth wrap around the ege)
it didnt' work and it made a scratch on the trim..
TIA
the eight clip"
i m totally suck
TIA
the eight clip"
i m totally suck
TIA
the eight clip"
i m totally suck
TIA
Step 1
Place one hand under the shift boot
Step 2
Place the thumb on the side of the console, right on the raised edge.
Step 3
Place your other hand or a few fingers under the shift boot if possible. Obviously, I have to hold the camera, so I can't show you the other hand.
Step 4
Place your other thumb right next to the first one for good leverage.
Step 5
With both thumbs resting on the raised edge of the console (side), use your fingers under the shift boot and lift up. Note : very importantly, only lift one corner at a time! By using the thumbs for leverage, you will have a very controlled lift of the console cover and not break anything.
Btw, once you have removed the front clips, the rear ones will come off easy.
Step 2
Step 3
Step 4
Step 5
What up Neo! Here are the directions I used to take out my center console.
http://andylee.us/gallery/console
I love all of you pics by the way man..!! I always love check those out in the photo gallery!
well i m at it again,
i give up for a week
i m going at it for the 2nd time now..
THANKS SO MUCH TSX536!!
ur instrutions worked!!
2nd problme:
for those who installed the players them self
there is a part where they ask me to "cut"
do i have to cut it???? or can i leave it?
cause i m gona cut it i m gona use a dremal and get it down... which might make
a mess....
2nd problme:
a mess....
Done!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks So Muhc For Ur Help Guys!
Is the player worth the cost? Did you get a good deal? $$$???
I wants PICS!!!
Originally Posted by slo007
So, did you cut or not?
I wants PICS!!!
I wants PICS!!!
i used wire cutters to cut maybe 1 mm off??? i certainly didn't need to cut
1 CM like wut hte instructions told me to...
worth the cost? for brand new (bought from acura), of course not...
was it a good deal? imo for the price i paid and oem fitment i think it is...
pics will be up tonight!
here is my mini review for far
1. the sound quality is better than i thought, thanks for tsx's 350watt..
2. even thought it's kenwood, it's not bad.
3. u know how when u turn off ignation and turn back on and if u had ur volume up high
it will go from minimal and increat it's way back up? well in mp3 mode that fuction is lost
so might get spooked by lound music if u dind't turn the vol down when u turn off the sterio
4. even at 128kbs (test cd was a back up mp3 cd i burned in 2000) quality is pretty good
at least good enough for me
Originally Posted by elduderino
So the volume setting starts out at the old elvel after crank when AUX is selected? Wow! Anyone else notice this?
ok just reazlied this while driving my car
the auto level thing works in aux.. however because it takes longer for the player
to read mp3 than normal cd's so by the time it reads the music, the level has
already been increased to the last setting
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
And you're welcome
