TL: Help with stereo upgrade
Old Feb 9, 2010 | 06:54 AM
APROBLEM4's Avatar
I have done a tone of research on stereo upgrades but im getting alot of mixed messages and I need help.
these are the specs.
* RMS Power Range : 400 Watts
* Peak Power Handling: 1200 Watts
* Impedance: 2 Ohm
* Low Frequency response: 37 Hz
* High Frequency Response: 150 Hz
* Diameter: 2 12 Inch sub woofer
Features
TN250/1 Amplifier Specs
* RMS Power @ 4 ohm: 100 Watts x 1
* RMS Power @ 2 ohm: 200 Watts x 1
* Frequency Response (-3dB): 20Hz to 85Hz
* Maximum Input Signal: 4V
Everybody keeps telling me I can't use the wires from the stock 8 inch sub.. And I need to run a bypass for the amp...
I need specific instructions on what to do.
Old Feb 9, 2010 | 07:36 AM
mattastick's Avatar
Regardless of how you get signal, you're going to want a bigger amp for that sub. It is better to have an amp that is "too" powerful for a sub than to have an amp that is underpowering a sub. Because if you turn that amp's gain up at all (assuming your LOC or HU has 4v output) you will start sending a dirty signal, if you're not already. This will start to destroy your sub...
Old Feb 9, 2010 | 04:59 PM
APROBLEM4's Avatar
questions answered
4drviper
Apr 23, 2025 07:13 PM
mlody
Dec 4, 2019 02:11 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
thegipper
Sep 28, 2015 01:01 PM
