Help with Icelink
Old May 3, 2005 | 07:07 PM
nhb04's Avatar
4th Gear
Help with Icelink
Hey all, just got the Denison Icelink to link my Ipod to my TSX. Pulled out the nav unit to hook it up and there is already a plug connected to where the Icelink should connect. The instructions say that if I don't have the XM or MP3 player (which I don't) then the connector should be available. Anybody know what that connector is for and if I can disconnect it?
Old May 3, 2005 | 08:10 PM
elduderino's Avatar
VP Electricity
Do you have the overhead video system?
Old May 3, 2005 | 08:19 PM
nhb04's Avatar
4th Gear
nope, no add ons
I got brave and unplugged the existing cable and hooked up the icelink. Icelink works fine but I have no nav controls. No touch screen, no buttons directly under the screen. What gives!
I have contacted Denison about the issue since their site mentions nothing about the unit not working with nav. If you guys have any ideas let me know since I doubt Denison will be much help.
Old May 3, 2005 | 08:21 PM
daniel1113's Avatar
You have the nav system, and have to do some work to use the IceLink. However, the new version of the IceLink is a bit different than the old documented versions. Would you mind taking some pictures? Then perhaps we can help you.
Old May 3, 2005 | 08:24 PM
daniel1113's Avatar
I should add, the Dension website does mention this issue:
Dension Knowledge Base
Just so you know if you do contact them.
Old May 3, 2005 | 09:25 PM
nhb04's Avatar
4th Gear
Thanks daniel1113. That helps alot. I am ordering the cable from acura tomorrow and will post picks of the install.
superJess
May 16, 2007 01:02 PM
dingobiatch
Apr 15, 2006 08:40 PM
underdog_RENAMED
Oct 15, 2005 02:51 PM
