CL: help another voltage problem
Old Jun 16, 2009 | 12:56 PM
on1wheel01's Avatar
well I've been messing with my set up trying to figure out why my hu keeps shutting off at high volumes. yesterday I wired my red and yellow wires from my hu together. it seemed to solve the problem. I just have to manually turn off the hu. now the problem is it seems I am having a draw on the ele system as when I go to start the car it is very sluggish after sitting over night. also seeing a dimming in headlights . now my ho alt is good and I have a extra batt in the trunk hc600 and my front batt is good also.and 0 wire all around and big 3 is done in 0 any ideas. it has to be hard wiring the hu my amp shuts off when I turn the hu off but I wonder if there is still a draw.ideas????
Old Jun 16, 2009 | 01:22 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
are you running a battery isolator for the rear?
Old Jun 16, 2009 | 01:33 PM
mattastick's Avatar
Here's probably what's going on: the batts don't have equal resting voltages. So when you turn the car off, the battery with the lower resting voltage is going to try to steal charge from the other batt. So the lesser batt will steal enough charge for it to be the higher charged bat, then the other batt will try and steal the charge back. In this process, you lose small amounts of charge each time... This process continues all night (and any other time the batts aren't receving charge) and so they'll slowly kill each other... An isolator should fix that problem, like Chris said...
Old Jun 16, 2009 | 01:39 PM
on1wheel01's Avatar
dont think thats it. the problem only started when i changed the wiring on the hu yesterday. put the + to the constant
Old Jun 16, 2009 | 01:42 PM
mattastick's Avatar
Was your hu skipping, and that's why it was shutting off? That happens quite a bit in cars deep into the 140's... Try holding the hu in your hand with it wired the regular way... If it stops shutting off, you've got your problem...
Old Jun 16, 2009 | 04:20 PM
on1wheel01's Avatar
no wasnt skipping i use the cd player and a mp3 player hooked to the aux. the cd player would flicker even when the amp was off.
Old Jun 17, 2009 | 06:53 PM
on1wheel01's Avatar
ok well this morning my batt was dead I got so pissed and ripped out the cd player and unhooked the wires. drove 4 mins to work yea short drive and after 12 hours it was still charged. now keep in mind the hu was off no lights on. what gives
Old Jun 18, 2009 | 05:28 PM
on1wheel01's Avatar
no ideas guys????????
Old Jun 18, 2009 | 06:06 PM
feuss2's Avatar
10001110101
This new connection is probably causing some devices that are normally not powered when the car is off to stay on (they are getting power via the constant power). This may be your amp and/or other things on the switched power line...
Can you make a diagram of how you have this set up?
Old Jun 18, 2009 | 06:10 PM
on1wheel01's Avatar
well i have the red + and the constant wired together behind the radio. my amp does shut off. i rewired it back after ripping out the hu. I decided to take off the face plate and see if that helps.
Old Jun 18, 2009 | 06:29 PM
feuss2's Avatar
10001110101
I think this is causing the problem. Anything else that is connected to that switch now has power all the time. Turning your HU off manually would not turn of any of the other unintentionally powered devices.
Is this a stock HU or aftermarket? What size fuse is going on the power wire to the radio?
Old Jun 18, 2009 | 06:52 PM
on1wheel01's Avatar
its a aftermarket panasonic no fuse wasnt one stock and i never use one
Old Jun 19, 2009 | 09:30 AM
feuss2's Avatar
10001110101
Which constant power and switch power have you twisted together? Have you made this connection across the vehicle wiring? Or have you connected both the switched and constant power lines on the HU both to constant power on the vehicle?
Old Jun 19, 2009 | 12:50 PM
on1wheel01's Avatar
just the red and yellow behind the hu using a wiring harness. this morning my batt was fine I took off the faceplate and seemed to not loose voltage. and now sincehooking it back up it is shutting off again after hitting. blah this problem is getting old. I don't see why it keeps happening.
Old Jun 19, 2009 | 12:54 PM
mattastick's Avatar
Have you put a DMM on the wires to check and make for damn sure it's a voltage problem?
Old Jun 19, 2009 | 01:37 PM
on1wheel01's Avatar
not on the wires behind the hu maybe I should check that out.now if it drops behind 12 would that shut the hu off
Old Jun 19, 2009 | 01:54 PM
mattastick's Avatar
Maybe... That's a question for Panasonic's customer support...
Old Jun 19, 2009 | 02:06 PM
on1wheel01's Avatar
well it also did it with a kenwood hu
Old Jun 19, 2009 | 02:42 PM
mattastick's Avatar
hmm... Have you tried running a power and ground wire directly from the battery to power the hu? Just take some speaker wire or whatever, add a fuse right behind the hu, and a switch, and try that... Might be something in the factory wiring...
Old Jun 19, 2009 | 03:25 PM
on1wheel01's Avatar
hmm might give it a try cuz man this is getin old
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
