Help - amplifier remote turn on lead ?
Old Apr 3, 2004 | 11:20 PM
callmetsx's Avatar
Spooooooon !
Question Help - amplifier remote turn on lead ?
I am installing a new Fosgate amp, and I was wondering what people have used for a remote turn-on lead in the TSX ? I really dont want to wire an in-line switch I would have to turn on and off every time I start the car.
If not the HU, I should be able to splice the wire with anything that turns on when the car turns on - right ? And if I can get to the HU turn on lead, where do I find it ?
Thanks for any help you guys can provide
Old Apr 3, 2004 | 11:46 PM
AJB_RENAMED's Avatar
... TSX you say?
If your mounting the Fosgate in the trunk (which I would assume you are) use the factory amp ACC wire for your remote. It's the YELLOW/RED wire. Grab a wire-tap from radio shack and tap into it. Clean, quick, and easy.
Old Apr 3, 2004 | 11:48 PM
callmetsx's Avatar
Spooooooon !
Sweet man - that would work nicely. Could you elaborate on where I can find it - I have not really explored the trunk area yet.
And can I just simply splice the wire ?
Old Apr 4, 2004 | 12:40 AM
ortiz's Avatar
Don't listen to me.
I think AJB is talking about the remote lead from the amp in the center console under the "not an ashtray". Here is the color code for the amps wiring.
amp wiring
Old Apr 4, 2004 | 08:14 AM
callmetsx's Avatar
Spooooooon !
Oh I see, so I actually have to take the panel apart. I was hoping to avoid dismantling too many things in search of the remote turn on.
Thanks for the diagram though, looks like the red/yellow wire is the one I'm looking for.
Old Apr 4, 2004 | 10:39 AM
Bass Mechanic's Avatar
actually looking at that chart i think its the yellow / green your looking for on the lower left hand corner. Radio Switch
Old Apr 4, 2004 | 11:49 AM
callmetsx's Avatar
Spooooooon !
Well - yellow/green is the radio switch, and yellow/red is the main ACC stereo power supply.
I assume ACC stands for accessory lead, and if that is the case I believe this is the correct connection, as the amp instruction manual says to connect the remote turn-on lead to the stereo accessory lead, or switched 12v source.
Any comments ?
Old Apr 4, 2004 | 01:28 PM
... TSX you say?
You want the ACC wire (Yellow/Red) as a remote turn on. The Radio Switch wire may work as well, you'd have to take a volt meter to it to be sure though.
Old Apr 4, 2004 | 01:56 PM
callmetsx's Avatar
Spooooooon !
Thanks AJB, I will give it a try this afternoon. That is - if I can find the wire behind the dash. I dont have a diagram of how to remove the panel.
Old Apr 18, 2004 | 03:10 PM
Dan Martin's Avatar
Photography Nerd
Did you end up using the Yellow/Red wire callmetsx? I have 400w pioneer amp lying around that I might hook up but I was wondering about the remote power switch as well.
Old Apr 18, 2004 | 03:39 PM
Altersys's Avatar
Use the radio switch lead. if the voltage isn't hjigh enough, get a low-amperage 12V relay, or even better, DEI's RTOL device (it's very low-current draw, as well as able to be triggered by as low as 5V).
If you usethe ACC lead the amps will ALWAYS turn on when the car turns on. That may or may not bother you, but it is technically incorrect.
Old Apr 18, 2004 | 04:01 PM
Dan Martin's Avatar
Photography Nerd
I think I'll just have the amp turn on whenever I turn the car on. Sounds easier and cheaper than using relays and shit.
Old Apr 18, 2004 | 04:22 PM
callmetsx's Avatar
Spooooooon !
Yeah Dan, I used the yelow/red wire as the remote turn on lead. Just spliced the remote turn on lead from the amp in and it works nicely.
It can be found behind the large storage compartment. There are no screws or anything, it just pulls out.
Old Apr 18, 2004 | 04:45 PM
Dan Martin's Avatar
Photography Nerd
Thanks callmetsx!
Old Apr 18, 2004 | 05:02 PM
callmetsx's Avatar
Spooooooon !
Good luck with the install - personally I'm glad I'm done !
Old Apr 18, 2004 | 10:10 PM
Dan Martin's Avatar
Photography Nerd
Should go smoothly I've done all of my own audio stuff in the past.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Azonics
Sep 22, 2015 05:28 PM
Sep 17, 2015 09:01 PM
