HELP!!! Amp Hookup Not Working Well..ASAP
Old Aug 18, 2001 | 09:43 PM
Guest007's Avatar
4th Gear
I have a 2001 CL, and I added an amp/subs today. I followed the posted instructions, but for some reason it doesn't seem to work but half the time. I tapped into the rear speaker leads (before the bose amp), and hooked them directly to the low level inputs on the amp. When I start the car with the radio on, everything powers up, but sometimes I don't get any sound. Turning the radio on and off a few times eventually works.Also, if turining it off and on doesn't work, you can unplug one side of the RCA inputs at the amp, plug it back in and it works! When everything is working, I get high volume clipping from the Bose Speakers. Please leave any detailed information possible. Would a Ground Loop Isolater help any of these problems?
Old Aug 18, 2001 | 10:39 PM
Guest007's Avatar
4th Gear
Some Help Please...I am waiting for a reply from Someone before I continue...I am trying to solve these problems tonight...Thanks
Old Aug 18, 2001 | 10:43 PM
mcdanjw's Avatar
If I'm understading you correctly, that's how I hooked mine up... been like that for months and no problems. I did have to use a ground loop isolator, but only to kill engine noise; it worked fine without it.
Did you make a good ground?
I take it you spliced rca's onto the wires you spliced onto the leads coming out of the head unit? If so, sometimes it's easy to let wires touch inside of the connector that might cause problems like you are describing.
Any feedback?
Old Aug 18, 2001 | 10:47 PM
mcdanjw's Avatar
Following up... are these the wires you used?
So:
1) yellow/white (5) is the radio switch that you used for the amp power on switch.
2) then you tapped the rear right speaker:
black (7)(-) & blue (20) (+)
3) and the rear left speaker:
green (9)(-) & red (22) (+)
I added the schematics to my website, if you click the link below...
[ 08-18-2001: Message edited by: mcdanjw ]
Old Aug 18, 2001 | 11:23 PM
Guest007's Avatar
4th Gear
We are now runnig from the Rear speakers using a Lineconverter/GroundLoopIsolater....The other way was now working. The Head Unit would power up but no sound unless you turned it on and off or unplugged the RCAs from the Amp and then back...and also the Bose speakers were clipping at med/high-high volume....HELP
Old Aug 18, 2001 | 11:29 PM
mcdanjw's Avatar
Bear with me, not trying to insult you...
Are you sure you got the right wires?
Are you sure you got them from the right 'side' of the factory amp?
Are you sure you put the right ones into the rca plug together?
This definitely sounds like a wiring issue...
Old Aug 19, 2001 | 01:02 AM
juicy's Avatar
6th Gear
Did you make sure you didnt cross the remote wire with the antena wire? Stranger things have happend.
Juicy
Old Aug 19, 2001 | 01:11 AM
Guest007's Avatar
4th Gear
We tried and retried several different ways just to make sure we were following the schematics right. We finally went and got a LOC and ran it from the powered side of the amp (rear speakers). Everything sounds GREAT now!
Old Aug 19, 2001 | 02:14 AM
LarryB's Avatar
Originally posted by Guest007:
<STRONG>We tried and retried several different ways just to make sure we were following the schematics right. We finally went and got a LOC and ran it from the powered side of the amp (rear speakers). Everything sounds GREAT now!</STRONG>
good to hear.. i would have guest bad ground. LOC is what i have setup in my car .. and it works great.
mada51589
Jan 9, 2025 04:40 PM
AndrewS
19
Mar 14, 2024 06:59 PM
acurajj
Sep 19, 2015 03:47 PM
Pegon95
Sep 15, 2015 01:54 PM
yahelou
Sep 6, 2015 09:12 PM
