Heavy duty wire harness help...
Old Oct 7, 2002 | 08:41 PM
KaMLuNg's Avatar
please help guys... i just got my heavy duty wiring harness today and im kind of confused... there is only one input where i plug in the harness from the factory... so does this mean i only need one feeding source from the car and can power both lights/??? if this is so then wat do i do with the other harness that i don't need to plug in??? tape it up so water doesn't condense in there???? i just want to make sure so i don't screw nething up... and another thing is, why do i need a constant source from battery and a new negative.. im just wondering about that...
Old Oct 7, 2002 | 10:17 PM
dnd2984's Avatar
what is this harness for? the Highbeams. I know my friend got a harness for his accord casue he has high voltage low beams. THey almost look like hids, almost.
Old Oct 8, 2002 | 08:54 AM
Avarice's Avatar
Kam,
WHere did you get the harness from? I want one too..
Old Oct 8, 2002 | 08:46 PM
KaMLuNg's Avatar
yeah they for the high wattage low beams.. HID look.. im running 140watts and i don't want to melt the harness... you can find them on ebay or even direct through a site.... just search heavy duty wiring harness and it will show on the forums...
Old Oct 8, 2002 | 08:50 PM
dnd2984's Avatar
ok on the harness u should have 2 things where it plugs in to the factry harness so lights will turn on when u turn the switch. u have 2 moer harnesses for the headlight assembly and your pos and neg right. Maybe do u think it only takes one input to turn on both bulbs???
Old Oct 9, 2002 | 10:26 AM
KaMLuNg's Avatar
thats what im asking cause i know other ppl here have installed it on there car... and i want to know if i only need one input to turn on both bulbs cause there is ONLY one input wire...
Old Oct 9, 2002 | 02:36 PM
Mike H.'s Avatar
I got my harness from suvlights.com for my C70. They way mine is setup is that the there is only one connection going to the stock wiring (well 2, 1 for lowbeams and 1 for highbeams). The upgraded wiring will then run across the car and power the other side. So basically I only have 2 connections going into the stock setup and not 4. There's a pic of a harness at the suvlights site to give you a better idea of what I mean. Hope this helps.
Old Oct 10, 2002 | 01:29 AM
KaMLuNg's Avatar
oh no wonder there were two sets for different sizes.. okay kewl ill try to put them in on friday... wish me luck....
tsx_boy
Dec 13, 2019 08:33 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
