TL: Headunit help!!
Old Mar 18, 2012 | 10:11 PM
westhaventl's Avatar
Moe T
Headunit help!!
So I just got a new JVC double din radio. Got the metra wiring harness as well. Matched all the colors up. Plugged te radio in and it worked fine. But when I turned my lights on at night the dash lights went out and I had no parking lights. I uninstalled radio and now my lights work fine except for when I use my high beams. The dash lights will go out again until I turn them off. Anyone have any idea of what I did wrong?
Old Mar 18, 2012 | 10:42 PM
Type-ES's Avatar
You wired something wrong.
Old Mar 18, 2012 | 10:43 PM
Moe T
If I take a pic do you think you would e able to tell?
Old Mar 18, 2012 | 10:56 PM
Type-ES's Avatar
Don't just go by the colors, if I remember there were one or two that didn't match.
go to the12volt.com to get a wiring diagram and match it up with the metra instructions.
Old Mar 19, 2012 | 01:08 AM
MilwaukeeDave's Avatar
I have a feeling I know EXACTLY what it is. U hooked up wrong orange wire for illumination. There's orange and orange/white. The wiring harness for the radio usually has orange/white on it I believe so it's easy to mess this up. Just switch them and u should be ok. If
I remember correctly you have orange/wh to orange/wh and that will blow a fuse for the dash lights etc.
Old Mar 19, 2012 | 05:09 AM
Skirmich's Avatar
Yup the Dimming wire (Orange) always becomes mixed up...
Old Mar 19, 2012 | 05:26 AM
I did same thing in my odyssey van and almost did it a second time after they stole the radio and I was putting in a new one. If you don't have anyone to ask ya just give it a try lol. But a so called "expert" from crutchfield actually told me twist the 2 together. Yea thanks a lot buddy there goes my last 15 amp fuse....
Old Mar 19, 2012 | 08:04 AM
Moe T
Ok so I had orange/white to solid white. :-(. Should I not hook up the orange/white(dimmer) at all?
Old Mar 19, 2012 | 08:26 AM
Hook orange/white from headunit to solid orange on metra/scosche harness. U need to hook it up for dash lights so just gotta swap it. Tape off the end of the wire u unhook as u wont need it. What's sucks for me is I wired my harness all extra pretty. Soldered all joints. Heat shrink cable ties etc then had to rip it up to fix same problem.
Old Mar 19, 2012 | 08:29 AM
Moe T
That's exactly how I had it in the first place Dave. I'm lost now lol
Old Mar 19, 2012 | 08:44 AM
Ok then reverse what I just said lol the orange is backwards how u had it.
Old Mar 19, 2012 | 12:10 PM
Moe T
Thanks guys that worked. Does anyone know what do I connect parking brake wire to for the DVD to work?
Old Mar 19, 2012 | 02:14 PM
You have to buy a 12v relay and fool the wire. Use this video as a reference:
Old Mar 19, 2012 | 06:46 PM
Skirmich's Avatar
Nope just ground that bastard so you can Use DVDs at all Times, I ground it to the HU Ground cable and worked like a charm! That cable only wants a ground point when you have the Gear in PARK, Out of Park and you wont have a ground = Wont Play DVDs.
If you want to cean install that Cable you will need to Tap in the Gear Lever cables IMO too much hassle....
Old Mar 19, 2012 | 08:32 PM
A lot of in dash DVD players won't work if it's grounded when it turns on. I use a relay turned on by the headunit remote wire to activate the relay and ground the parking brake wire after the HU is on.
Soul_Deamon
Nov 13, 2018 04:44 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
cltypes6spd
Dec 25, 2002 01:58 AM
aaron1017
Nov 6, 2002 02:39 PM
