headunit
Old Dec 14, 2008 | 12:01 PM
invisiblewar's Avatar
an asshole from florida
headunit
I tried to search and didnt really seem to find a straight forward answer. Can I change the speakers in the CL to aftermarket and still leave the oem headunit in?
Old Dec 14, 2008 | 12:35 PM
nf3d0149ab's Avatar
I'm confident you can.
Why couldn't you?
The only thing is that you might not be able to use the stock Bose amplifier.
Old Dec 14, 2008 | 12:36 PM
nf3d0149ab's Avatar
I put a head unit in first and there was an issue hooking up my speaks to the headunit but they figured it out.
Something to do with the Bose amplifier compatibility which makes me think you would run into the same issue vice versa.
Old Dec 14, 2008 | 12:42 PM
aznboi2424's Avatar
I believe the issue is that the stock bose amplifier has an output signal of 1 ohm. There are not very many speakers that can run down to 1 ohm.
But im sure you can do it where you run a seperate multi-channel amp, bypassing the stock bose amp. I think members have done that. but you have to do wiring to all 6 speakers.
Old Dec 14, 2008 | 12:44 PM
wiring isnt a problem, my friends all know how to do that and if worse comes to worse my two brothers are electricians and should be able to figure it out
Soul_Deamon
Nov 13, 2018 04:44 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
cltypes6spd
Dec 25, 2002 01:58 AM
aaron1017
Nov 6, 2002 02:39 PM
