Hard wired my Valentine one
Old 07-24-2004, 10:53 AM
CJ Majesty's Avatar
Finally got my helms manual.
First Disconnect neg terminal & waited a few minutes ...probably didnt have to but just to be safe.
I pulled the rubber down out of the door &
Took off the A pillar...very carefully
There one more clip inside & it pops off real easy.
Next & I dropped the front of the head liner to run the wire to where im gonna mount the V1.
Stuck a screw driver in the back of the sunvisor hook, twisted it & pulled it out.
Poped the cover that conceals the screws for the sunvisor pivot
& unscrewed it
Ran the wirefrom the gap in the headliner behind the rear veiw mirror
to the a-pillar opening.
Dont wake up the sleeping side airbags.
I snaked it down the a pillar along side the wires in the plastic tube (forgot what its called) that were already there
down down down behind the dashboard...
Now here is where it get tricky lest take a long walk into under dash world.
Ideally what & wanted to do was piggly back that white & red wire &&&&
Ground it here....can you see it...I know its blurry.....Grounding point.
However I figured that Id rather have easy access to it should something go wrong plus one day I might want to add one of these
so I ran the wire back under the dash to the console to the back of the the accessory socket
now its time to mount the direct wire hardware they gave me.
Old 07-24-2004, 11:19 AM
CJ Majesty's Avatar
I went directly behind the cig lighter in the this is not an ashtray box & piggy backed the pos & neg. The pos piggy back clip came from valentine one in there kit the small neat one to the right..(white& red wire look familiar) the big square one came from radio shack the wanted you to groung it to a grounding point but the U shaped neg conector they gave me was to small so I cliped it off & used these....
The negative wire comes along side the wire instead of crossing it like a T obviously
Old 07-24-2004, 11:31 AM
CJ Majesty's Avatar
Now to mount it. It came with two sided tape.
its new home
Old 07-24-2004, 11:38 AM
CJ Majesty's Avatar
Blurry but I was driving ...you get the point.
Old 07-24-2004, 11:41 AM
CJ Majesty's Avatar
Yeah it was raining the whole damn time. 1 large umbrella two jackets.
Old 07-25-2004, 01:58 PM
kurt_bradley's Avatar
Nice install and DIY instructions.
Trust me, I'm not trying to sound rude on this part. Just helpful: Move the actual V1 unit down a couple inches below your mirror. So maybe it doesn't look concealed, but then you can actually put the whole 360 degree ability to use. If you're going to hide a radar detector, don't spend your $$$ on a V1. You're taking away from its effectiveness if it doesn't have a clean line of sight behind and around you.
Old 07-25-2004, 07:26 PM
iron_chef's Avatar
Man I hereby take my hat off to you for doing all this in the pucking wetass rain
Now what is this business all about here ??? installing a radar detector ?
Honestly bro, you should loose that cheapass air freshener...don't belong in this car.
Brings bad luck, IMO...(seems to me a lot of wrecked car have one of that in the car...)
May I suggest something like this, sir :
or if you don't mind something japanesy:
Old 07-25-2004, 09:42 PM
CJ Majesty's Avatar
Hard wiring it as oppose to this
Old 07-25-2004, 10:21 PM
Bye TSX, hello domestic?
xizor's Avatar
awesome pics, nice writeup!
Old 07-26-2004, 12:34 AM
accsuperstar's Avatar
swweeet your center console looks a bit dirty there
Old 07-26-2004, 12:43 AM
CJ Majesty's Avatar
WAS a bit dirty... I cleaned it up real nice. Now it looks clean
Old 07-26-2004, 08:19 AM
John Starks - The Dunk
yuhoo22's Avatar
Great install and instructions!
Old 07-26-2004, 04:52 PM
CJ Majesty's Avatar
Thanks guys
Old 07-26-2004, 06:47 PM
where'd my wheels go?!
zazen721's Avatar
nice work buddy... sorry it was so crazy yesterday and i couldnt talk =)
Old 07-26-2004, 11:10 PM
CJ Majesty's Avatar
Its all good. I couldnt stick around because I had to drop the girl I was with off & pick up my girlfriend.
Next im gonna try to half tackle my system. I figured since I was under there pokin around Id try this just for kicks...
This is a polk audio tweeter i want to put in the factory location. .........
& I wondered if it would fit right in in without cutting it
& as we can see ...Might need a lil K-Y jelly to get those in
I took the ring off & tried to fit it.
That gives you an idea of how much we'll have to cut.
Well save that for another day
Old 07-27-2004, 12:09 AM
CJ Majesty's Avatar
correction my next task is to get the Ipod Ice link.
Old 07-27-2004, 08:39 AM
dabuda's Avatar
next work CJ!
Old 07-30-2004, 01:22 AM
CJ Majesty's Avatar
Originally Posted by dabuda2004
next work CJ!
thanks
Old 04-22-2005, 09:59 AM
smock9's Avatar
Great detailed instructions.
I just got myself a radar detector. Does this DIY generalize beyond your model?
I got one of the cobra models.
was the wiring part of a kit for your detector or a kit in general or just parts you got together yourself.
Old 09-23-2005, 08:25 PM
Roman-dude's Avatar
do you have a picture of the actual radar?
thx
Old 09-25-2005, 05:34 PM
blueingrid's Avatar
For radar detectors with no extra modules or whatever, it seems easiest just to route the wire up the rear view mirror stalk and into the map light housing, then hook into the power to the autodimming mirror, ground it on a screw, the end.
Takes 15-20 minutes tops with minimal disassembly of the interior.
Old 09-25-2005, 06:57 PM
Youse Gots Sacked
NFLblitze1's Avatar
that might not be the smartest thing to do, because then ull have constant power running to the detector...no? and then u can possibly drain the battery and keeping the detector on all the time wouldn't be a good thing either..
Old 09-26-2005, 02:26 PM
CJ Majesty's Avatar
Either way you do it, whether it be the accessory outlet or the mirror they both cut power when the car is turned off.
If the car is on & I want it off I turn the knob to off.
Neither have constant power if the car is turned off.
Old 09-26-2005, 02:45 PM
Guinea Pig
CJams's Avatar
I had to search to find out what the hell a Valentine one was. I guess its a radar detector. But my question is.....I saw you take apart the car and run some type of wire.....why isn't that wire hooked up to the radar detector in the pic? And with all the dismantling of the car wy didn't you hard wire the radar detector?
Old 09-26-2005, 04:20 PM
Audio Enthusiast
Jputt's Avatar
Nice work, I have been contemplating hardwiring mine for quite sometime now.
Old 09-27-2005, 03:36 AM
CJ Majesty's Avatar
that is a before pic
the after pic is a red X
ill re post it when I find it.
some of the more important pics are red x's
Old 12-13-2005, 05:02 PM
dailo's Avatar
Are there some pictures missing? I remember I saw this thread a while back and thought the unit was installed underneath the sun visor? I was thinking about doing something similar, but I was worried about the range if I put it there. Thanks.
Old 05-08-2006, 12:26 PM
dwiller's Avatar
I'm thinking about the Escort 8500 or Bel RX65. I saw a post on here somewhere where the guy hardwired into the fuse for the shut-off button for the passenger windows. I would like to do that as well, using the hardwire kit for Escort or Bel. Do you just put one of those add-a-circuits into the fuse for the passenger window shut off button, and then plug the hardwire kit into that? That sounds pretty easy. I'm thinking I could just do that instead of finding a place for a mute button. I have a Bel 980 and if I'm on the phone I have to pull the plug out of the 'not an ashtray' power to shut it off. I'd love to have it on the switch for the window shut off.
Old 07-22-2006, 12:41 PM
Just dial 1911
joerockt's Avatar
Wired my V1 with the help of this thread. Thanks CJ!
I still have yet to mount the consealed display. But I ran the wire for it to the center console. I was thinking of mounting it inside the "not an ashtray" compartment.
Also, someone mentioned that mounting it that high may cause problems. I really dont see a problem with it because if I look in through my back window (though the tint), and put myself at eye level with the V1, it has a clear view out the rear. Should work fine...
Old 06-22-2007, 08:37 PM
taz98spin's Avatar
Some of the images don't show up.....
When you said "piggy back" does that mean, you connected your wires to the "white & red"
wires??
Old 06-23-2007, 10:38 AM
G22_Powered_YA1's Avatar
wires??
well the thread IS about 3 years old
but usually when you say piggy back on an install like this you tap into a current power line and then send it to the detector through another wire, youd buy a wire tap, crimp it into the power wire, and then connect the RD wire to that via a connector of some sort, theres also the ghettoer ones that use the power wire inline and then the other wire inline, both crimped into the same 1 piece setup
Old 06-24-2007, 08:37 AM
taz98spin's Avatar
So according to the OP of this thread, you piggy back onto the "white & red" wire.
So as long as I piggy back and ground the wires, I'm good to go, right?
I don't have to add an extra fuse, or mess with the fuse box, if I just tap into the
"white & red" wire.
Old 06-24-2007, 10:05 AM
"white & red" wire.
you should only do something like that if your hardwire kit had an inline fuse on it, otherwise you might wanna add a fuse on there to be safe
Old 12-15-2010, 11:12 AM
9th Gear
spudsmac's Avatar
Major bump, but what do you think about hardwiring to the rear view mirror? I have a dashcam I want to wire in and I just want it to have power when the car is on.
Old 12-17-2010, 01:16 PM
9th Gear
spudsmac's Avatar
I wired it up with posilock connectors. Took about 10 minutes. Will post photos later.
Old 12-17-2010, 02:44 PM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
that is usually fine to use the rear view mirror...
08KBP_VA
10-22-2019 01:55 PM
ITSJESTER
4G TL Photograph Gallery
10-13-2015 12:53 PM
SUPRMN84
10-07-2015 09:46 PM
xsilverhawkx
10-05-2015 11:00 AM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
Quick Reply: Hard wired my Valentine one
