grounding location
Old Mar 7, 2005 | 01:04 AM
robeaneee's Avatar
grounding location
i posted a while ago about my amp just cutting out...we isolated the problem to be the ground location...i searched many times for answers, but i can't seem to find anybody that says where the best place to ground is. my amp was originally grounded in that little area under the trunk floor..i duno if you guys know what i'm talking about but a piece of it lifts up...if ur lookin in the trunk from outside it's above where the spare is, right in front of the opening from the armrest int he backseat. there was a round metal looking thing in there so we ground it to that..but it keeps cutting out. anybody have a suggestion for a better ground?
Old Mar 7, 2005 | 01:09 AM
robeaneee's Avatar
also, detailed instructions of how to access the particular spot and how it should be grounded would be appreciated, thanks in advance.
Old Mar 7, 2005 | 01:19 AM
palidanx's Avatar
honk not beep
which car?
Old Mar 7, 2005 | 01:29 AM
robeaneee's Avatar
03 cl-s
Old Mar 7, 2005 | 08:43 AM
elduderino's Avatar
VP Electricity
If you get a good reading with a voltmeter across your amp's + and - terminals. you don't need to look for a better ground.
Old Mar 7, 2005 | 10:16 AM
Jonesi's Avatar
http://silverknight.clickhere2.net/sound.html
Second picture.. This location known to be a good ground..
Old Mar 7, 2005 | 03:14 PM
robeaneee's Avatar
that's where it was grounded...interesting...maybe my amp just sucks
Old Mar 7, 2005 | 06:27 PM
elduderino's Avatar
VP Electricity
Well, you have a problem to trouble-shoot, but that might be a bit premature... what amp, what speakers?
Old Mar 7, 2005 | 09:57 PM
robeaneee's Avatar
i have a hifonics 500 W amp, stock components and a 12 inch RE sub..the thing is, my friend was able to fix the problem before by changing to a new ground location..it worked fine for about 4 days and it just stopped working again, i can't really figure out what the problem is..i tried adjusting the ground a bit, but no luck so far.
Old Mar 7, 2005 | 10:22 PM
elduderino's Avatar
VP Electricity
I suggest that maybe that wasn't it... but you won't find out without a voltmeter, I'm afraid.
Old Mar 8, 2005 | 12:02 AM
robeaneee's Avatar
do you have any idea what it MIGHT be? anything to narrow it down would help. 2 days ago, my amp just randomly started working, and then stopped working..i see my indicator LED light up and my sub works, and then 5 minutes later it turns off again...this cycle goes on and on, but now it doesn't turn on at all..what might be disrupting the power?
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
