Fuse Box Option...
Old Apr 9, 2001 | 01:29 PM
VTEC Animal's Avatar
Fuse Box Option...
Thought I'd post this here just in case it's the same for the CL as it is for the TL. I'm not sure, I haven't been able to verify if the CL has the same fuse box configuration... But check this out and you might find some information if you're gonna put in some aftermarket electronic stuff....
http://www.acura-tl.com/ubb/Forum8/HTML/000458.html
2001 Acura 3.2TL Non-Navi
Satin Silver
35% Metal Tint
Old Apr 13, 2001 | 01:28 AM
WV250R's Avatar
I used the switched plug in for my radar detector hard wiring. Works great.
Old Apr 15, 2001 | 08:13 PM
N-Gin's Avatar
Drunk Bastid
Cool. My Civic Si had these connections in the fuse box and I wondered if the CL did as well. When I hardwired my V1, I had an old minifuse Add-A-Circuit(TM) lying around, so I just used that instead of searching for an auxiliary power tap. I connected the Add-A-Circuit to the AUX fuse.
BTW, here's what an Add-A-Circuit is. I haven't heard anyone here mention these, but they are invaluable when adding stuff to the fuse box.
http://www.littelfuse.com/ASP/Search/detail.asp?ID=243
Available at most auto parts stores.
~ Drew ~
2001 White CL Type S
If you're interested, check out my suspension install page for a 6th gen Civic:
www.cybermesa.com/~drew
[This message has been edited by N-Gin (edited 04-15-2001).]
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
dirleton
Sep 28, 2015 07:05 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
