Final word on how to hook up a amplified sub to the stock system
there are 2 conflicting views here... One says it is ok to hook the speaker level inputs of the amp to the 9" bose sub, the conversation can be seen here
http://www.acura-tl.com/ubb/Forum8/HTML/000367.html
the other says you tap into the signal on the HU side of the stock amp and run that into the line level inputs on the amp... Is one better than the other? Does one work and not the other?
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by sniper_mjh on March 25, 2001 @ ]</font>
Mine is working perfectly, I tapped it into the wires going into the factory sub. I tried to tap the wires before the factory amp and the signal was just too low.
I wouldn't worry about using the signal going to the factory sub because it isn't really high powered. It is rates at 100 watts at 1 ohm. But that's because the sub is rated at 1 ohm. So if you are using it for 4 ohm purpose, the power will then be 25 watts.
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads. Mugen front grille. 2 Polk/MOMO 10" subs, Orion Xtreme 500.4 amplifier and Alpine CD changer.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. Matriz ion yellow fog light bulbs(courtesy of Snook). More to come later......
Acura-MDX.com Forum Moderator
My AcuraTL Homepage
My preamp solved my problem with the low signal from the rear speaker signal. The preamp increases the signal voltage, thus letting my amp recieve better signal. Sounds great, just afraid that my rear view mirror will fall off soon with all the bass.
For those who is using the 9" woofer's signal, know that your only getting low freq...so dont go and try to use any multi-channel amp to run mids and tweeters.
99' Taffeta white TL
"It Aint Real Bass unless It hurts just to sit in the Car"
Fosgate Power 800a2
Two 10" Hx2
E750s Lanzar Preamp
Fosgate Power 800a2
Two 10" Hx2
E750s Lanzar Preamp
cycdaniel
Dec 17, 2019 10:58 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
