Final answer is?
Old Jan 16, 2007 | 08:49 PM
buckeye78's Avatar
Final answer is?
I have read posts about adding an aftermarkrt amp to the door speakers until
I'm blue in the face!!!! Is there a real answer to how to do this? Does anyone have a set up that is trouble free and easy for a shop to do? There are no real good shops in my area so I need to keep it as simple as possible for them not to
screw up my baby. I want to add a JL 300/4 but I'm still not convinced that it can
be done with out problems. Anyone with experience please chime in!
Old Jan 17, 2007 | 10:26 AM
bullyx2's Avatar
'05 TSX CG W/NAV
What car/year
Old Jan 18, 2007 | 12:36 AM
buckeye78's Avatar
sorry forgot audio/video is an open forum. 04 non nav TSX.
Old Jan 18, 2007 | 09:03 PM
dnd2984's Avatar
The cleanest sound will come with u add the JL Cleansweep, then that to the 300/4....Its a simple upgrade...
Old Jan 25, 2007 | 11:07 AM
helomech's Avatar
5th Gear
I have an 06 tsx w/ nav and from dealing w/ auto shops and not getting good results, I installed a complete system to my factory stereo. First of all, a JL cleansweep will do nothing for you. In the TSX (nav or no nav), the factory stereo has no preset sound output. so basically the wires from your stereo to your factory amp are the same as any aftermarket pre amp outputs (minus the rca plugs). To do things right all you have to do unplug the wires to your factory amp and wire them into rca plugs to run to your aftermarket 4 channle amp. It is actually a simple process in which you will only have to buy rca connectors ($5) and rca cables. If you use quick splices (I did) you can always put everything back to factory if you get another TSX. I can help more if this is the answer you're looking.
Old Jan 25, 2007 | 11:16 AM
helomech's Avatar
5th Gear
Here is a link to explain more.https://acurazine.com/forums/audio-video-electronics-navigation-22/instructions-install-shop-preamp-output-300209/
Old Jan 25, 2007 | 01:51 PM
Reach's Avatar
ElD swears no cleansweep is necessary in a TSX. Take it fwiw.
Old Jan 27, 2007 | 11:18 PM
buckeye78's Avatar
yea I,ve read that post along with all of the others. All of them seem to have problems with one thing or another. I just upgraded my sub to a JL12w3v2
and now feel that I need to amp my door speakers to keep up with the bass.
If there is a solution with minimal problems thats what I'm looking for. Like I said before I have zero faith in the install shops around me.
Old Jan 29, 2007 | 08:04 PM
JAXFLTSX's Avatar
MAC USERS RULE
So you went with the 12. good choice. Did you make the spare tire box?
mitchigan
May 29, 2019 06:53 AM
vpasla1
Sep 17, 2016 07:24 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
thegipper
Sep 28, 2015 01:01 PM
