Everythings hooked up but no sound out of subs
Ok i resently put in a new head unit and had a shop run the power remote and rca wires i hooked everthing up and the amp turned on so i hooked up the subs but the subs don't do anything i turned up the gain and the boost on the amp and the radio everythings up but the subs are not moving has anyone else run into something like this?
depending on what box and stuff you are connecting to, check that the subs actually work by hooking the speaker wires that you would connect to the amp to a power and a ground wire, you should hear the sub move "it'll just be a short little pop" if not that, then HU, if not that then RCA connections on HU i would say, just incase tho
good luck
good luck
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
some H/U's come with the sub starting in the OFF setting. turning it on should do the trick... I'd turn down the gain on the amp first though...
