Engine noise all of a sudden
Old Jan 30, 2007 | 02:38 PM
dailo's Avatar
Hi everyone. I've had a system installed on my 04 TSX for about a year and there was no engine noise at all before, but now I get the high pitched noise that gets louder as I rev harder. I know there are some solutions out there, but how can the noise all of a sudden just appear? I've checked all my connections and they all seem to be fine. I know it's definately coming from the head unit, because when I pull out the RCA's on my amp the noise goes away.
Which GLI is everyone using these days to get rid of this noise?
Old Jan 30, 2007 | 05:52 PM
SeeVuPlay's Avatar
I just had the A4300 JL Amp and a 10W1V24 (4 omh) this past weekend and mine does the same thing!
Anyone in the know? Other than the annoying buzz/whirring, the sound goes in and out slightly.....how depressing as I was really looking forward to upgrading and now it seems you spend all this money for something worse.
Old Jan 30, 2007 | 07:14 PM
seanberry's Avatar
How did you connect your HU to the amp? Did you do the conversion requiring you to connect RCA female heads on your stock wiring?
Old Jan 30, 2007 | 08:05 PM
SeeVuPlay's Avatar
I didnt do the install, but according to the installer, thats what he said he did. Is that good thing or a bad thing?
Old Jan 30, 2007 | 08:48 PM
dailo's Avatar
I did the conversion and tapped into my stock HU wires to make female RCA cables.
Old Jan 31, 2007 | 01:17 AM
CLevr098's Avatar
sounds like a connection got loose somewhere, most likely a signal ground on one of the rcas.....is it noisy in all of the speakers???......can u unplug them from the amp one at a time and see if any are significantly noisier than the others???
Old Jan 31, 2007 | 01:41 AM
dailo's Avatar
Good point. I only notice it from my speakers on the left, I guess I'll check the RCA connections on that side.
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Phambam12
Sep 6, 2015 06:57 PM
