in door speaker wire connections
Old Oct 18, 2002 | 05:36 PM
eggbert's Avatar
Question in door speaker wire connections
Hey.
I haven't ripped open my doors yet, but am going to put in a pair of DX6 polks this weekend.
I'm going to do the mods listed in this forum, but was wondering about the actual connection to the speakers.
I've read about clipping off the tabs that stick out and could possibly touch the doors.... will the stock connectors fit the speakers or is everyone just soldering the wires to the terminals?
Old Oct 18, 2002 | 05:54 PM
Iggy's Avatar
Eggbert,
You're on the right track, and yes you will have to clip the stock connector as it will not fit the Polk. You can solder the connections or splice a bit of the wire provided with the speakers onto the factory wire and use the spade connectors. Personally I prefer to solder but that does not mean you have to.
If you can, after you have connected the door panel wires but before mounting the panel, Roll the window down and peer into the door from the top(where the window comes out) with a flashlight. You will be able to make certain that the window properly clears the speaker wires.
Good luck,
Iggy
Feb 25, 2020 09:57 AM
akbears15
15
Nov 5, 2015 07:06 AM
VA2000TL
Oct 2, 2015 08:26 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
alan_rich
Sep 7, 2015 11:08 PM
