Does Aftermarket Head Unit Work with Navi?
Old Dec 11, 2004 | 07:08 PM
Doc Holliday's Avatar
Hi,
I have 3000 dollars worth of stereo equip that I want to put in my 2000 Acura TL with Navi...
I believe it gets tricky because of the Navi... Car Toys has the kit for the double din dash mount because I have an Alpine hu and a digital Alpine EQ (Erag 320).
There are 2 routes to go...
1. Leave in the stock unit and use rca converters to hook up amps (erag)..
2. Gut the stock unit all together and replace everything.
I'll get to my question for the techs...
If I remove the stock head unit will it disable my Navigation Unit's audio and/or video? I can live without the audio prompts if I have to but the Video... I need the Visual display to work.
Sound quality might be worse by leaving the stock unit in and doing the converters (option 1) but, I don't know how much worse it would be than option 2.
Please let me know about the navi and if anyone has hooked amps to the stock unit (with aftermarket speakers of course).. plz let me know what it sounds like.
Yours Truly,
Jeremy
Old Dec 11, 2004 | 08:41 PM
lbbrando's Avatar
Acura Dealer Technician
The navi screen is seperate from the radio unit.
The navi unit is in the trunk.
No worry's.
Old Dec 11, 2004 | 09:19 PM
bkzjimmy's Avatar
NiGhT rIdEr
Originally Posted by Doc Holliday
Hi,
Yours Truly,
Jeremy
i think u should just give me ur navi
Old Dec 11, 2004 | 09:24 PM
ou sig's Avatar
Boomer SOONER
You will lose your voice prompts...but like me, I didnt care because I thought it was annoying anyway!
Get the stock unit out and replace everything!!!! It sounds like you want a real good system, not just an upgrade. You wont be happy if you keep the stock unit for many reasons...SQ and functionality for the main two.
Old Dec 11, 2004 | 10:02 PM
Need Tech Advice
Does anyone know with experience for sure if the aftermarket head unit will let me keep the visual display working on my Navigation unit?
Also, will a little bass in the trunk mess it up?
Old Dec 11, 2004 | 10:08 PM
ou sig's Avatar
Boomer SOONER
umm did you look at my sig???? I have NAVI with a new HU and everything is fine. And no, subs wont do anything to the NAVI unit, I have the old hard drive version and it fucked up my disk, but I have the flash memory version now and its all good.
Old Dec 12, 2004 | 03:04 AM
What is the navi flashcard or flash memory? Mine is a dvd in my trunk... is that it?
do you have pics?
Did the installer have to do anything weird in order to keep the visual part of the navi working?
Old Dec 12, 2004 | 11:17 AM
ou sig's Avatar
Boomer SOONER
My navi...'99 isnt DVD. It looks like a hard drive out of your computer, but is removable. So I got a drive that is flash memory...like your digital camera, no moving parts. But the only reason I did that was my original hard drive disk basically got old and was very tempormental to temperature extremes in the summer. But subs wont hurt your machine at all.
I was turned away by some shops...cause they didnt know about the NAVI, like yourself. I found a local shop that the owner acutally has a '03 Type S, but w/o navi. We just decided to go for it, normally and unhook whatever we needed to to install the new unit. Turns out, the only thing that is connected with the stock HU and Navi system is the voice. EVERYTHING else works exactly the same so dont worry if you want a new HU - go for it.
what pics do you want? I have everything.
Old Dec 12, 2004 | 11:26 AM
I hope my DVD NAVI is hooked up the same as your flashcard NAVI...
About the pics... bring em on... send me a link or just throw em on the post... I love pics... Your radio installation pics would be cool and your system...
Old Dec 12, 2004 | 11:45 AM
ou sig's Avatar
Boomer SOONER
Here is my HU and you can see the NAVI working. The shitty mounting plate was only temporary untill I got the Metra kit in, so it looks very nice now. I dont have my digital camera anymore so its not updated yet. And yes, your NAVI is hooked up exactly the same as mine. The '99-'03 NAVI's are interchangeable. I am looking to buy the DVD unit now to replace mine and it is just plug and play.
Back door component
Front door component
Capacitor mounted in the "ski hole"
Front panel of the box made around NAVI system. This works nice because I really dont use my trunk now, but when I do I will get it redone and make the space more useable. The sub box is pretty small... only 1.1cubic feet/sub. But we just got it to look clean.
Old Dec 12, 2004 | 05:04 PM
Hey... Looks good... The installer guy said that I wouldn't need a capacitor... I only have a 400 watt amp and a 100 watt mono for my sub... and a radar detector that's extra on top of the navi...
Do you think I should get a Single Far or whatever capacitor... maybe a light one?
Old Dec 12, 2004 | 05:39 PM
ou sig's Avatar
Boomer SOONER
Ya it looks MUCH better now that I got the Metra dash kit and wet sanded it to make it match the rest of the stock plastic surrounding it. No you wont need a capacitor with that kind of power. I have 1100 watts RMS and I barely need it. I just didnt know about our stock electrical system and I got a real good deal on it. One thing is for sure, a capacitor will NOT hurt any. I kinda tested it by putting a bass cd in, turning both heated seats on, NAVI on, lights on and at idle, the reading on the Capacitor never went below 12.5 volts. So basically everything works perfectly even with the max load.
The rule of thumb is to get 1 farad/1000 watts of stereo. So you could if you want or they even make a 1/2 farad.
Old Dec 12, 2004 | 06:48 PM
Capacitor Question
Who makes a good capacitor?
tell me who or which brands to stay away from plz.
or better... tell me who to go with
:gheywave:
Old Dec 12, 2004 | 07:02 PM
ou sig's Avatar
Boomer SOONER
Really they are pretty much the same...I have Stinger, Rockford Fosgate makes them...Lightning Audio does, really not one to avoid that I know of. Just get one that you like. I guess I would recommend Stinger or Rockford.
Old Dec 12, 2004 | 07:45 PM
Thank You
Old Dec 13, 2004 | 09:10 AM
LiQiCE's Avatar
Liquid Ice
This has already been answered, but for the DVD based Navigation system, the video is fed completely separetly from the audio. So if you pull the stock headunit and put in something else, the video for the NAVI will be completely uneffected.
You can maintain the NAVI voice prompts by buying a box like this one:
http://www.crutchfield.com/S-KWYvA6Z...600&I=469MPSS4
Only $37.99. I'm not sure how the audio from the NAVI hooks up, so you may need a line level to RCA converter as well.
You really only need the front speakers to be connected, unless you want the voice prompts to override the front and rear speakers. The NAVI should automatically send a 12v signal to the PIE box when it wants to talk.
Old Dec 13, 2004 | 02:47 PM
99TLKID's Avatar
L33t Sk8er
I have a 99 and was wondering about this.......I really want to change to a better head-unit but I thought it would affect the Navi........My navi is the Hard-drive version........So will I be able to do this....does anynone have this same one and have done it?
Old Dec 13, 2004 | 05:42 PM
ou sig's Avatar
Boomer SOONER
Im going to bite my lip here and not be rude, but please at least read the whole thread before you ask this. If you would have you would have seen I too have the '99 with the Navi system and the pictures are of my car!
Feb 25, 2020 09:57 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
acurajj
Sep 19, 2015 03:47 PM
yahelou
Sep 6, 2015 09:12 PM
trinikidcl
Sep 4, 2015 12:56 AM
