Couple of questions
Old Mar 10, 2007 | 04:21 PM
Rapmaster0's Avatar
Couple of questions
I've been reading around and searching, but I still have a few questions.
-When installing a 4ch amp, do you guys splice the wires for the speakers or is there a harness?
-Should I just splice the RCA jacks to get preamp outputs or go with something like the JL CleanSweep?
-What kind of LOC should I get to install an aftermarket sub?
-Any recommendations for aftermarket speakers for inside the car? (I was lookin at the Focal 165a1 and the Boston Acoustics FS60)
If it helps, I already have an JL 12w7 and JL 500/1, and I am planning to put in Doms TV2Nav.
Old Mar 10, 2007 | 04:27 PM
Rapmaster0's Avatar
Also, its a 2006 TSX.
Old Mar 10, 2007 | 07:12 PM
Fatalilluzionz's Avatar
i did splice the wires dont think there is a harness. i added mb quartz components 6x9 and coaxils . they are extremely clear great speakers and i have a jl 300/4
Old Mar 11, 2007 | 01:40 PM
Reach's Avatar
Fatalilluzionz, do you have any noise in your setup, or popping, or other undesired effects due to the aftermarket amp?
Old Mar 11, 2007 | 06:21 PM
Rapmaster0's Avatar
Do you have a sub Fatalilluzionz?
Old Mar 12, 2007 | 08:57 AM
Ron Burgundy's Avatar
Just the facts...
Are you running the stock HU?
Old Mar 12, 2007 | 03:54 PM
No my sound quality is actually extremely clear at times too clear. I do not have a sub but I have already ran the rcas from the HU so i can sort of just plug in the amp when i do get subs. im shopping around for a deal on some subs. The HU i am using is the Pioneer N3 but i was using the factory HU with the aftermarket amp.
Old Mar 12, 2007 | 05:01 PM
Rapmaster0's Avatar
Do you think I should use a relay that is used here https://acurazine.com/forums/audio-video-electronics-navigation-22/diy-kick-panel-install-doms-unit-2006-tsx-341061/
or go with SNHOND3? The relay would be so much cheaper, and I think it would be better so I don't have to flip and switches or anything.
Old Mar 12, 2007 | 05:10 PM
Reach's Avatar
Did you have a shop do it or did you make the connections yourself? I'm curious about where the wires were tapped, and if you used a common signal ground or the individual wire grounds, as outlined here.
Old Mar 13, 2007 | 09:19 AM
Rapmaster0's Avatar
Does anyone know what DVD player I should get also? The don't sell the Accelvision 8500 no more!
Old Mar 14, 2007 | 12:04 AM
Rapmaster0's Avatar
I'm down to two sets of speakers, but don't know which one to choose!
-JL XR650CSI (Front)
-JL VR650 CSI (Front)
-JL XR650 (Rear)
*I still have to pick which components, either the xr or vr.
orrrrrrrr
Focal 165A1 (Front)
Focal 165 CA1 (Rear)
Can I get some input on which to get? I'm leaning towards the JL, but I'm not sure.
Old Mar 14, 2007 | 10:36 AM
I did use a common signal ground and sort of used that wiring diagram. ill take pics soon and post them. I just have to clean up a few things so i have to take up the n3 any way.
Old Mar 15, 2007 | 02:32 PM
Rapmaster0's Avatar
ANy comments?
Old Mar 15, 2007 | 02:51 PM
i like JL but then again i went mb quart.
Old Mar 15, 2007 | 03:43 PM
Rapmaster0's Avatar
You like them better? And what do you have for front and rear speakers?
Old Mar 16, 2007 | 01:55 PM
Rapmaster0's Avatar
Anyone?
Old Mar 17, 2007 | 09:32 PM
buckeye78's Avatar
For mids highs= MB Quart or Focal you cant go wrong
JL makes great subs just not sold on their comps
Old Mar 18, 2007 | 04:01 PM
Rapmaster0's Avatar
What brand though? I just don't know what to get for front and rear speakers :-/
Old Mar 18, 2007 | 08:41 PM
buckeye78's Avatar
for your fronts get the best speaker you can afford. Focals are great you really cant beat their sound quality. Next is MB quart (I have the q line in my front doors)
rear spakers are not as important they are used for rear fill. scrap you 6x9s if you havn't already and leave the holes open. You would be suprised how much this inceases you bass spl. But once again these are only opinions. Use your own ears
before spending money!
Old Mar 25, 2007 | 02:59 PM
Rapmaster0's Avatar
Okay I need any opinions before I buy these. I have decided to get the Focal 165A1 and the Focal 165Ca1. Any comments before I buy on Monday??
Old Mar 26, 2007 | 06:48 PM
Rapmaster0's Avatar
Anything???
Old Mar 27, 2007 | 11:33 AM
csmeance's Avatar
not to change subject, but i could not find a place that sells MB Quartz speakers, and yes, I googled it.
Old Mar 27, 2007 | 12:54 PM
markh's Avatar
http://www.google.com/search?hl=en&q=MB+Quartz
try the top result
Old Mar 27, 2007 | 03:24 PM
Rapmaster0's Avatar
Another question has arose while thinking about modding my system. When I do bypass my bose amp to install an 4 ch amp, do I install an LOC for the sub in the back? The amp is an JL 500/1.
Old Mar 29, 2007 | 01:59 AM
Rapmaster0's Avatar
Anyone??? No one can help??
Old Apr 10, 2007 | 10:50 AM
Rapmaster0's Avatar
Bump.
Old Apr 11, 2007 | 10:05 AM
bullyx2's Avatar
'05 TSX CG W/NAV
If you bypass the stock amp then you do not need an LOC. The 500/1 though isn;t a 4 channel amp. What exactly do you have? Do you have a 4 channel and the 500/1?
Old Apr 11, 2007 | 04:54 PM
Rapmaster0's Avatar
Yes. Keeping the whole stock unit. Where do i get the inputs for the 500/1 then?
Old Apr 12, 2007 | 08:38 AM
bullyx2's Avatar
'05 TSX CG W/NAV
is a 500/1 the only amp you are installing or are you installing a 4 channel as well?
If you are only installing a 500/1, you can simply convert the rear deck speaker wires to RCA and connect them to the 500/1. You will not need an LOC. I did this with my 250/1 and it works PERFECTLY. If you go buy honda speaker harnesses from Circuit City or Crutchfield for under $10, you won't even need to cut any wires.
If you are installing a 4 channel as well, you would do it entirely differently. Best way then would be to follow the instructions elsewhere on this site to convert the stock pre-amp outs to 4 full range RCA's. Run those to your amps and use the internal x-overs in the amps to divide up the sighnal.
Old Apr 12, 2007 | 10:40 AM
Rapmaster0's Avatar
Do you have an aftermarket system?
Old Apr 12, 2007 | 11:29 AM
bullyx2's Avatar
'05 TSX CG W/NAV
My system is completely stock with the exception of the 250/1 and a JL 10w3 sub. The rear 6x9's have been disconnected but are still in place.
Eventually I will be replacing the mids/highs with aftermarket sets and a 4 channel. Mosy likely a 300/4 although I really like the new Alpine amps and may go that route.
Old Apr 12, 2007 | 02:14 PM
Rapmaster0's Avatar
I found out that I have the Audiobahn A4004T amp at home. The specs can be found http://www.crutchfield.com/S-fcU0cBi...120#morephotos . My question now is that do I just add RCA's from the stock radio to the amp and use the output on the Audiobahn to the 500/1 in the back?
Old Apr 13, 2007 | 08:29 AM
bullyx2's Avatar
'05 TSX CG W/NAV
That should work fine. However, If you are not 100% confident in your install ability, I would recommend maybe spending the few extra $ and having a professional do the work for you. Preferably one who has a lot of experience with OEM integration. This is not the most straightforward install and you have a really nice car, would be a shame to mess it up.
Old Apr 13, 2007 | 01:52 PM
Rapmaster0's Avatar
Yeah, but CC and BB would not cut it for me. They SCREWED my 500/1 into the back seat of my RSX and made some nice holes when i TOLD them to put it on the box, and they used drywall screws.......guess how much i got back when I traded it in.... and Tweeter made a custom box for my 12w7 and made it sideways. They didn't rebuild it because they claimed that I already payed for it and can't return it.
Old Apr 19, 2007 | 10:54 AM
Rapmaster0's Avatar
Is there a place where I can get a replacement cable that comes out the stock radio to the stock amp so I can splice those apart instead of my stock cable?
Old Apr 19, 2007 | 09:52 PM
mercman's Avatar
I should have all the parts to make the amp bypass cable assembly next week. One end of the cable will allow you to plug into the 14 pin connector (removed from the amp) and the other will provide front and rear channel RCA plugs and a remote turn on wire. No need to cut, splice or solder.
jeff
Old Apr 20, 2007 | 12:39 AM
Rapmaster0's Avatar
Alright, how much would each connector be?
Old Apr 20, 2007 | 08:51 AM
bullyx2's Avatar
'05 TSX CG W/NAV
jeff
Hi Jeff. I sent you a PM a week or so ago, but please count me in on one of the connectors as well. I have the know how to tap the stock wires, but I am all over a solution that doesn't require cutting stock wires.
Old Apr 20, 2007 | 11:26 AM
Reach's Avatar
Mercman is just doing this as a project right now. Remember that for him to sell anything over Acurazine, he will need to become an official vendor. Lets see how these go and if he wants to sell these to us later.
Old Apr 20, 2007 | 02:20 PM
bullyx2's Avatar
'05 TSX CG W/NAV
All apologies. Mercman, I would be very interested in assisting with testing on your project and would be more than happy to compensate you for your time and effort in building a connector for me to test.
