CLS Speaker depth
2001 CL Type S
CLS Speaker depth
I've searched for quite a while and can't seem to find the answer to this question. What is the mounting depth of the door speakers? I have a set of Alpine Type X 6.5" comps I'd like to install; they are 2.75" deep, which is quite a bit. How thick of an MDF ring can I use and still have the door liner go back on without a problem. Also, I plan on sound deadening the doors so that will also take away a little room.
2001 CL Type S
Originally Posted by richiehawtin
Did you ever find an answer to this question? I am dealing with the same thing right now.
Another interesting detail is there's a "pocket" in the doors that the crossovers fit into as well. The installer said he had never seen anything like it. The pocket was formed in the factory by Acura and it must have been for spacing purposes as nothing else went inside it.
Thanks for the follow up. That helps me out a ton. I just picked up the CL-S about a month ago. It is pretty hard to find specs and kits for the stereo, man. No double din kits, the HU is a bitch to replace, the Bose system.
If you don't mind I have another question. What about the HU? Can it be wired in with the harness or do you have to run new speaker wires to bypass the Bose amp/eq?
Thanks.
Thanks.
You can fit almost any speaker in there as far as depth goes - as long as you don't mind kicking out the back of the speaker bracket (what i did). Another thing you need to worry about is the width of the speaker housing (the metal piece that the magnet connects to). Ive found that gets in the way more than mounting depth.
2001 CL Type S
As for the HU, Metra makes a double-din kit to install a single din HU. http://www.metraonline.com/vehicleguide.aspx
The model # is 99-7868. My installer took the Bose (blows) system out so I can't help you with that.
kb1rl
09-30-2015 10:17 AM
polish_pat
09-25-2015 12:24 PM
4drviper
09-23-2015 09:00 PM
