Changer
Old Jun 15, 2003 | 01:03 PM
Changer
Does any one know if 2000 TL, is wired to the trunk, from the HU, to install a changer, or I will have to wire it myself?
Also Any body knows if I want to connect the changer to the HU, without disconnecting HU from the battery, does it make any harm? Since I don't have my anti-theft code.
Thanks,
Old Jun 15, 2003 | 02:05 PM
StanMan's Avatar
i think it is NOT prewired so you would have to run the cable yourself and it's ok to not disconnect the battery if you are careful (but shouldn't matter).
Old Jun 16, 2003 | 11:35 AM
songoku's Avatar
BlingBling INSPIRE 32V
YES, it's NOT prewired. You don't have to disconnet the battery cable if you don't want to.
BTW, you can get the anit-theft code if you have serial # on the back of the HU from the dealer.
Old Jun 16, 2003 | 12:51 PM
Thanks for the repies
Old Jun 16, 2003 | 03:45 PM
JKJ1718's Avatar
9th Gear
The code is located on the side of your glove compartment. There should be a white sticker label on your left side of the compartment when you open it. That is your radio anti-theft code.
Old Jun 16, 2003 | 04:33 PM
I'll try to find it, thanks,
Old Jun 16, 2003 | 04:59 PM
songoku's Avatar
Somebody actually posted that there's anti-theft code on the strut tower inside the engine compartment, but we couldn't find it. He never replied back.
I think it's same case here.....
Old Jun 17, 2003 | 12:00 AM
JKJ1718's Avatar
9th Gear
I think it is how the dealership preps the car. I think that is one of the things they do is to label in a hidden place just in case you lose your radio code. Therefore in my car, it is on the left side of the glove compartment. If it is not there, then you can bring your VIN# to a Acura dealership and they will be able to look it up in their database for the radio code.
Old Jun 17, 2003 | 11:29 AM
Mine is the same way Paul...no hoax here.
Old Jun 17, 2003 | 01:04 PM
songoku's Avatar
Then, why not mine??
Old Jun 20, 2003 | 02:10 AM
Smile Changer
I'm planning to put a changer in my 2000 TL also, but I am not sure if my HU supports it. I have the standard HU and no NAV. I don't see any controls on the HU that would give me any idea if it does support a changer. Does anyone know if it does?
Old Jun 20, 2003 | 11:07 AM
Re: Changer
I have a 2000 TL no navi and I have an alpine changer that is controlled by my stock HU. So, yes it does, search for alpine changer and you will get all the information you need.
Old Jun 20, 2003 | 04:40 PM
thanks for the info
Old Jun 23, 2003 | 02:39 PM
Ok, I got a Alpine S601 changer from a friend, but no cable, can anyone tell me what adaptors and cables that I will need to install the changer. I don't want to go to the store and get ripped off for not knowing the average prices for these items. Thanks
Old Jun 23, 2003 | 03:25 PM
VTEC11's Avatar
Yeah, i also need the cable.
I have the honda changer out of a 2000 accord, but the cable is only 5 feet, because it came with teh console mount kit..
I want to put it in the trunk. Do you need a kit to mount the factory changer in teh factory spot in the trunk? or can you just drop it in there?
thanks,.. and where can 1 get the std. honda/acura cable?? Do anyone have a spare??
thanks !!
Old Jun 26, 2003 | 05:31 AM
spindle's Avatar
replace 2000 with 2003
have you thought about replacing the stereo with the newer 2003 models with the 6-disc in dash changer?
That's what I would do if I wanted to add more capacity...
Old Jun 26, 2003 | 07:44 AM
TL-IGHTS's Avatar
Registered Abuser
I do have a sticker in that location, however it tells me the anti-theft code for my navigation, as well as the serial number. I have memorized my radio code for convenience.
Matt
Sep 21, 2015 08:44 AM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
Chris.Su
Aug 13, 2002 07:09 PM
ChrisK_RENAMED
Mar 15, 2001 04:05 AM
