Car went in today!
Old Jul 11, 2001 | 03:34 PM
Patryn's Avatar
Car went in today!
My car finally went into the shop today to have everything installed. I should be picking it back up sometime on Saturday. 3 1/2 days for the install. Gah!! But it should sound damn good once I get it back. Here's the list of what I finally ended up with:
Nakamichi CD700 head unit
Nakamichi MB70 6disc in-dash changer
Focal Utopia 165W 6.5" components
Brax X2000 amp (190x2) for the components
Eclipse 88120DVC subs (2 of them)
JBL BP1200.1 amp for the subs (1200x1)
Illuminations (made by Kimber Kable) D60 .5m digital interconnect to connect the CD700 & MB70 (will bypass the dac in the MB70 & use the CD700 dacs)
Kimber Kable 4tc speaker wire for components & subs
Kimber Kable Hero interconnects for the Brax amp
Kimber Kable PBJ interconnects for the JBL amp
They will be building enclosures in the doors for the Focals as I have no room for kicks unless I remove my left leg. New battery will be going in, caps if needed, Dynomat for the trunk lid at least, if not the side panels also. A bit will be used on the doors also, how much will depend on if the door rattles after the enclosure is done.
It should be interesting.
Old Jul 12, 2001 | 02:10 PM
cl-driver's Avatar
wow. sounds like an awesome system. all high end stuff. lots of $$$. now you can really enjoy your music. please post pics when finished.
Old Jul 12, 2001 | 10:04 PM
KikAzCL97's Avatar
Sounds good! Post some pics if you can.
Old Jul 13, 2001 | 09:08 PM
Vector02's Avatar
Let me know how that instal goes with the utopias....i didn't think i'd be able to fit them in my doors....but if you can...i'd love to pic up a set....
Old Jul 13, 2001 | 10:09 PM
Patryn's Avatar
Just called the shop to check on the progress. They had no trouble fitting the Utopias in the doors. They did have to slightly modify the bracket to fit the tweeters in though. 2" tweets. Jeez. They'll be doing the amp racks & finishing up the trunk tomorrow. It should be good.
Old Jul 14, 2001 | 03:48 PM
autophile1's Avatar
Hey Patryn,
How much did your cables end up costing you? How much of each wire did you need? Also, please let me know if you have any problems with the Nak CD-700/MB70 (skipping, not playing certain discs, jamming...). As I have told you before, my system will be similar to yours, just trying to work out the last few details Thanks
Old Jul 14, 2001 | 04:44 PM
Patryn's Avatar
Originally posted by autophile1:
<STRONG>Hey Patryn,
How much did your cables end up costing you? How much of each wire did you need? </STRONG>
I'm sure some people are going to just shake thier heads and some people are going to scream like banshees when they read this.
Kimber Hero 5m was $293
Kimber PBJ 6m was $161 w/WBT connectors
Illuminations D60 .5m was $140
Kimber 4tc - I have a 17ft pair and a 10ft pair - total was ~$340
I'm picking it up today so I'll play with it more then.
Old Jul 14, 2001 | 09:32 PM
autophile1's Avatar
That's actually not that bad. I am thinking of using the Silver Streak's, 4TC, and the Illuminations... Did you get this from Peter?
Old Jul 15, 2001 | 02:11 AM
Patryn's Avatar
<STRONG>That's actually not that bad. I am thinking of using the Silver Streak's, 4TC, and the Illuminations... Did you get this from Peter?</STRONG>
I got the Illuminations from Peter. I bought the IC's from another person. 25% off retail. The speaker cable was bought from 2 different places. It was a piecemeil thing.
Using Silver Streak could get expensive. A 3m length of that is $560 retail, let along a 5 meter run. You're almost into the Kimber Select price range then.
Old Jul 15, 2001 | 02:16 AM
GOT PSI?'s Avatar
It's Go-Time.
I use to work for Nakamichi Canada...the CD700 is a decent head unit, but it had problems recognizing burned cd's. The CD700 essentially has mostly Sony guts and laser, with a bit of Nak parts.
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
PAK74
Sep 3, 2015 09:02 PM
voigt
Sep 2, 2015 10:44 PM
