Car Audio Advice Needed
aka gimmesomesugar
I currently have Alpine Type R components(mids, tweeters, and 6x9's) powered by a Rockford Fosgate 300X amp. Also, I currently have one 10W7 powered by a 500/1 amp.
My future goal would be to add in two more 10W7's.
With this in mind, which component speakers and 4 channel amp would make for a better setup? I'd prefer to stick with JL Audio, but I've been hearing very good things about Focal components.
Also, with the two additional 10W7's, should I run a 500/1 to each sub or just use a 1000/1 amp? Are there any advantages or disadvantages of having three 500/1 amps as opposed to one 1000/1 amp and one 500/1 amp?
If I go with the 500/1's, I would be saving a couple hundred dollars.
U can just had another 500/1 and W7. For the mids and highs I love teh way the type Rs sound why dont you put the Rockford Fosgate 551x. U will notice a huge differ and your sound will be much more cleaner. Since everyone here is a JL fan they all will say get a 300/4. Which is a never awesome amp to.
personally i am a jl fan but i would not go with jl components.. i would go with focal, diamond audio or maybe some cdts... as for the amps... well that is a little tricky... the 1000/1 will not work... two reasons i say that.. one each w7 is 3ohms... wired in parallel that would be 1ohm.. the jl is only stable to 1.5ohms.. yest i am sure it could probably handle the .5ohm difference but you would still be under powering the speakers... if it was me i would look at either the diamond audio d5 1200.1 or maybe a us amps... but that is just me.....
The other huge issue is Current Draw.... I really doubt that your alternator can support 3 500/1's, and a 4 channel.... You may want to get an upgraded version... Also, for the amount you spend on extra amps and subs, you could do a great install... by the way, with the amount of current you could draw, you may want a second alternator....
Whoa... 3 Dub7's... I have a few questions.
What headunit do you have? Do you plan an upgrading your alternator? Do you plan on competing? And Why three?
If you still have the stock headunit, I would upgrade that first. When I got my system installed, I kept the stock headunit and it sounded like shit. My new Alpine deck sounds a hell of a lot cleaner that the stock.
If you do decide to get three, I would suggest getting 2 sets of components. That is, if you plan on hearing some music and not just bass. Try listening to some Utopias. I love the way mine sound.
If it were me, I would just add another W7 and 500/1 to what I have now.
Good luck with your system.
aka gimmesomesugar
It never occured to me to upgrade the alternator...I'll look into that.
No plans to compete...only for my personal enjoyment. The reason I want three is to destroy my friend who has 12" RF HX2's
Originally posted by KyleWatson
wuzzzz... Have you thought about adding more power to your Utopias?
Soul_Deamon
11-13-2018 04:44 PM
