capacitor broken?
Old Dec 26, 2004 | 02:47 AM
MistaWrongy's Avatar
capacitor broken?
well i was disconnecting the ground and power wire from the cap when i accidentally touched the two metals together while they were still on the cap because the tool i was using was metal. It sparked and blue the fuse under the hood. I didn't use the cap because i had a former amp that was broken and so i was stuck with a shitty 500 watt amp. I just got another 1500 watt amp and havent tried my capacitor yet. But do u guys think that my cap is broken?
Old Dec 26, 2004 | 08:24 AM
shawhite's Avatar
nope.. i think the cap should be just fine... basically all you did was arc a cross the leads which basically discharges the cap.. a cap will store voltage like a battery.. usually when a cap goes bad it will either swell up on the end or it will discharge the dielectric inside of it (oilly substance.)..
Old Dec 26, 2004 | 05:13 PM
DerrickM's Avatar
probably fine. you can test it by seeing how long it keeps a light bulb illuminated. (common way of charging/discharging them).
Old Dec 26, 2004 | 08:39 PM
ResidualFreedom's Avatar
2400 Watts in a TL...Why?
agree with the two posts above....I've done that many many times over the years, your cap is/should be fine.. If you want you can check it with a tester (voltmeter)..... I've personally done that to a cap that was sitting for over a year and i still showed a perfect 12v..
dainmezron
Oct 16, 2015 06:56 PM
steve
Sep 30, 2015 09:23 PM
polish_pat
Sep 30, 2015 12:22 PM
juanrl
Sep 29, 2015 03:25 AM
darksky
Sep 5, 2015 03:11 AM
