capacitor broken?
capacitor broken?
well i was disconnecting the ground and power wire from the cap when i accidentally touched the two metals together while they were still on the cap because the tool i was using was metal. It sparked and blue the fuse under the hood. I didn't use the cap because i had a former amp that was broken and so i was stuck with a shitty 500 watt amp. I just got another 1500 watt amp and havent tried my capacitor yet. But do u guys think that my cap is broken?
nope.. i think the cap should be just fine... basically all you did was arc a cross the leads which basically discharges the cap.. a cap will store voltage like a battery.. usually when a cap goes bad it will either swell up on the end or it will discharge the dielectric inside of it (oilly substance.)..
2400 Watts in a TL...Why?
1 Post
agree with the two posts above....I've done that many many times over the years, your cap is/should be fine.. If you want you can check it with a tester (voltmeter)..... I've personally done that to a cap that was sitting for over a year and i still showed a perfect 12v..
dainmezron
10-16-2015 06:56 PM
darksky
09-05-2015 03:11 AM
