Can amp pop be fixed?
Old Sep 4, 2004 | 03:15 PM
Aman00's Avatar
Well I am just about finished installing my system in my 2000 TL and there are just a few issues to rectify first, then I hope to post some pics. My four channel amp (US Acoustics USX4065) has a turn on pop and I am wondering if there is anything I can try to fix it? I pulled the amp from my sisters Acura Legend, and there was no pop on it when it was in that vehicle. Thanks for any help!
Aaron
Old Sep 4, 2004 | 04:08 PM
Blazin_TL's Avatar
Registered User
u have it hooked up to factory hu? when does it pop?
Old Sep 4, 2004 | 04:20 PM
Aman00's Avatar
No, it is hooked up to an aftermarket H/U and the amp is connected to the H/U through RCA's. It pops about 5 seconds after car is turned on. It is one single pop, not a continuous popping.
Aaron
Old Sep 4, 2004 | 04:32 PM
Blazin_TL's Avatar
Registered User
make sure your rcas are in tight.. your getting power out of your amp right?
Old Sep 4, 2004 | 04:38 PM
Aman00's Avatar
Yeah, i don't know about the H/U RCA connections, but amp RCA connections are in tight. Yes I am gettin power out of my amp, and it works great other than the initial start-up pop.
Aaron
Old Sep 4, 2004 | 04:45 PM
Blazin_TL's Avatar
Registered User
it could be a handfull of things.. your hooking up woofers to this amp right? it could be the power going to the subs.
Old Sep 4, 2004 | 04:51 PM
Aman00's Avatar
No, this amp is powering the door speakers of the car (aftermarket). I have a separate amp powering a sub.
Aaron
Old Sep 4, 2004 | 06:27 PM
AcuraX2's Avatar
More than likely it is just the amp itself. What kind is it? Most amps have a turn on/off delay to avoid this problem but, some amps do not. I have Memphis amps and I have a slight turn off thump. The only way it might hurt is if you have it really cranked and the pop comes thru. Might strain a speaker that way.
Old Sep 5, 2004 | 12:04 PM
Aman00's Avatar
It is a US Acoustics USX4065. If i am not mistaken this amp does indeed have a turn-on delay. Is it possibly just not set for the correct delay? (I hear on some amps you can adjust this delay)
Aaron
Old Sep 7, 2004 | 07:34 AM
Scott P's Avatar
Mobile Elec. Guru
usually something like that is caused by a grounding issue. What i would do, in this order is make sure the fuse on the constant power wire is of a high enough amperage (kind of a useless step, but do it just to be safe). make sure that you are indeed using the same guage constant power wire as your ground wire. make sure that you have a good grounding location, and if all else fails try adding a relay to the remote turn on wire.
Old Sep 9, 2004 | 01:10 PM
Aman00's Avatar
what do you mean exactly by a relay?
Jul 16, 2017 07:33 AM
Fool
Mar 10, 2016 08:42 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
