big 3 on a 01 CL
Old Nov 20, 2006 | 02:06 PM
belcom's Avatar
09 TL SH-AWD
big 3 on a 01 CL
anyone done a DIY ? where to mount on the alternator, engine? chassis will probably be easy enough. how long the cables should be and where to route them?
Old Nov 29, 2006 | 12:00 AM
belcom's Avatar
09 TL SH-AWD
never mind, was easy enough to figure out. but I'm surprised that no one has done it and no one could help
Old Nov 29, 2006 | 02:35 AM
SpeedyV6's Avatar
What are the big 3?
Old Nov 29, 2006 | 07:02 AM
KaMLuNg's Avatar
so the question is, did you have a writeup for the other members on here???
Old Nov 29, 2006 | 08:07 AM
belcom's Avatar
09 TL SH-AWD
Originally Posted by SpeedyV6
What are the big 3?
sometimes the stock ground wires are not good enough. They rust and corrode and don't perform very well. That's not good for anything, including your engine performance, audio system and whatever else. Also with high current alternators and audio systems the stock ground wiring is simply not enough. So to remedy the situation you need install 3 wires under the hood. Preferably they have to be high strand zero gauge wire to provide the best possible current flow (about $3-$4 per foot)
1. battery negative to chassis (this one is quite obvious)
2. engine to chassis (because the alternator body is the absolute ground and it is attached directly to the engine)
3. alternator positive to battery positive (help with the charging current I guess)
This will also help with dimming lights issues, noise in sound system, maybe even increase the spark intensity and gas mileage. Overall improvement for your electrical system basically and as it turns out not too hard to do.
Old Nov 29, 2006 | 08:11 AM
belcom's Avatar
09 TL SH-AWD
I installed just one so far and had no time to finish but maybe I'll snap some pics on the weekend when I finish up and then educate the clueless ones on the subject.
Acura604
2G RDX Photograph Gallery
17
Feb 8, 2021 03:32 PM
Jul 16, 2017 07:33 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
Froid
Sep 27, 2015 06:16 PM
