View Poll Results: Which Amp
The Hifonics Brutus
100.00%
The Rockford Fosgate P1000-1BD
0%
Voters: 3. You may not vote on this poll
MISC: Between these 2 momo amps:
Old 08-06-2009 | 10:39 AM
SG81's Avatar
Missing My CL-S
a buddy of mine has 2 amps, both are brand new. he's going to keep one and use it and i can have the other. not sure which one to get.
the amps are:
1) HIFONICS BRUTUS BXi-2010D Class-D MONO AMP
* Parametric bass EQ with 45Hz bass boost and variable control from 0db to 10db
* Variable Low Pass, Subsonic Filter, Phase Shift and Level Control
* Balanced line input for MX accessories and line drivers
* Remote Bass Remote included
* Built-In System Diagnostics protects from short circuits, over load, thermal overheat and DC Offset
* 650 Watts RMS @ 4 Ohms
* 1300 Watts RMS @ 2 Ohms
* 2000 Watts RMS @ 1 Ohm
* Dimensions: 14.97"L x 2.52"H x 9.45"W
2)
ROCKFORD FOSGATE AMPLIFIER P1000-1BD
# mono subwoofer amplifier
# Not bridgeable
# 250 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
# 1000 watts x 1 at 1 ohm RMS
# Low Level signal input and output 1 RCA Pair each
# Block power input connector
# 4AWG power wire cable required (not included)
# Screw terminal barrier strip speaker output connector
# 8AWG to 18AWG speaker wire cable required (not included)
# Cast aluminum heat sink
# Convection cooling system
# Optional remote bass knob PEQ (overrides built in Punch EQ2) (sold separately)
# optional wired remote bass boost
# Class-BD amplifier design
# Frequency response 20Hz to 250Hz +/- 1.0dB
# Visual indicators - Power, Thermal and Protect
# Punch EQ2 Bass: 0dB to + 18dB @ 45Hz
# Infrasonic Filter: selectable 12dB / Octave, -3dB @ 28Hz
# Crossover controls : Low-Pass (LP): 35-250Hz 12dB/octave Butterworth
# Efficiency (average) : 86% @ 4Ohm, 84% @ 2 Ohm and 76% @ 1 Ohm
# 7.625"W x 2.25"H x 14.375"D ( 5.71H x 19.37W x 36.50L ( cm ))
Old 08-06-2009 | 10:41 AM
SG81's Avatar
Missing My CL-S
i will be running down to 1 ohm
Old 08-06-2009 | 11:08 AM
mattastick's Avatar
On what sub(s)? What's your electrical system like? That will determine what amp you should run, even though they will probably be pretty close on current draw, with the Hifonics pulling a little more than the Rockford.
Old 08-06-2009 | 11:11 AM
SG81's Avatar
Missing My CL-S
Right now, i have 1 of this sub:
a Rockford P3 2ohm DVC
http://www.rockfordfosgate.com/produ...n_US&p_status=
i may add another P3
Old 08-06-2009 | 11:15 AM
mattastick's Avatar
I'd go with the Brutus. Run it at 4 ohms until you add a second sub, then drop it to 2 ohms. Those subs should take the power just fine, as long as the enclosure is good.
Old 08-06-2009 | 11:38 AM
SG81's Avatar
Missing My CL-S
thanks mattastick
Old 08-06-2009 | 12:11 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Hifonics Brutus for sure, I have one and love it
Old 08-06-2009 | 09:13 PM
feuss2's Avatar
10001110101
I clicked to find out what a momo amp was
mrmonster
07-14-2005 08:31 PM
Moodist
02-24-2005 11:13 PM
Jamz
12-03-2004 01:34 PM
red99cl2.3
11-02-2003 09:47 AM
SlyTLS
01-26-2003 08:29 PM
Quick Reply: MISC: Between these 2 momo amps:
