Best Amp for 2 12" Kicker CVR
Mostly Stock For Now
hey guys
i bought 2 12" Kicker CVR subs in a ported box but not quite sure what kinda amp i need. subs put oout 1600 watts. help please
heres some specs
Model CVR12
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 800/400
Sensitivity (dB 1w/1m) 86.7
Frequency Response (Hz) 25-500
just lookin around i found the Sony Explode Amp 1200 watts. what do you guys think of sony amps?
price range under 150
heres some specs
Model CVR12
hey guys
heres some specs
Model CVR12
heres some specs
Model CVR12
And sony amps are probably the worst available... don't waste your money...
CL in lawnmower status
^agreed, sony sucks balls do not waste your time with them. you'd be better of giving me the money that you would pay for that amp and i can just kick you in the balls, would save you a lot of time and frustration
but as far as amps, you would need to first post what voice coils your subs have, and get an amp that will push out around 800 W RMS at the impedance you would have to wire the subs at. I'd usually suggest around 900W RMS or more, but with a ported enclosure it's easier to damage your subs with a lot of power, so i'd say anywhere around 800 and you should be good.
again, post more info of your subs
i have a sony Explode 800w Amp n its powering 2 12'' sub (2000w) i never had any problem. they sound good better then any other amp i had
U need a Mono (1-Channel) amp if u only want to power the subs don't get more then 2 channel amp cause its going to sound like ass
^if you want to use a 4 channel amp for subs that would be fine, it's just it would run a lot hotter and a lot less effiecient than a class D amp (which is what most mono amps are). And some of the 4-channel amps are not bridgeable to my knowledge. The only thing that are better about the class A/B 4 channel amps would be the sound quality, which is not really noticeable for subs
Emran247, there are many things wrong with your post... First off, you 800w Sony Explode probably isn't putting out any more than 200w RMS (the value that actually counts, not your MAX watt value). Same thing goes for your subs... I can almost guarantee that if you hooked ONE of your 2000w subs to my 1200w RMS amp, it would be blown in about 5 minutes. 2nd, you do not need a mono or 2 channel amp to power subs. You can use a 4-channel, but you'd have to bridge the channels. This is an option, although it is more likely going to be more expensive.
OP, check out Hifonics amps, as they are pretty cheap, and put out some decent power... But check your impedance on the subs first, so you know what kind of power you'll be needing...
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
Medinak12
09-23-2015 07:11 PM
