Basslink Location/etc
Old Jul 21, 2004 | 09:35 PM
Moodist's Avatar
I did a couple of searches on where the basslink was mounted...has anyone found one spot to be better than another? Also, how bad does the trunk rattle with the basslink installed? Thanks.
Old Jul 22, 2004 | 08:35 AM
fuzzy02CLS's Avatar
My trunk only rattles a little. Not enough for me to care about. Either facing the rear of teh car, or in a corner will give you the best bass response. However the trunk is a closed space so you will get good bass out of any location. Your best bet would be to have some longer wires so you can position it around in your trunk & decide what sounds best.
Old Jul 22, 2004 | 09:13 AM
UNCTYPE-S's Avatar
Above n Beyond
either right behind the driver backseat or the passenger. my trunk didnt rattle any either. with my new setup......different story.
Old Jul 22, 2004 | 11:59 AM
Moodist's Avatar
Well that is good to hear, I really don't want any rattle. I was thinking I might have to put some dynamat behind the license plate, if anything.
Old Jul 22, 2004 | 03:28 PM
Rod's Avatar
Rod
Just use two small pieces of double sided tape if your license plate rattles. Worked for me.
GoDucksCLSPride
21
Jun 4, 2004 07:49 AM
tsixp
May 26, 2004 04:25 PM
97AcuraCL
17
Jun 28, 2003 11:09 AM
Hardcore_Newbie
May 27, 2003 01:49 AM
