Bass Governer?
Old Jun 1, 2004 | 09:59 PM
icey's Avatar
The Young One
Bass Governer?
Has anyone experianced this problem? The higher the volume on the radio the lower the bass goes? I just installed Alpine Type-R subs along with the Alpine 1000watt amp. And when I go over 20 on the volume the bass drops out. Anyone know whats going on?
Old Jun 2, 2004 | 03:54 AM
Jasonrdec's Avatar
Actually I believe it cuts Treble and Bass to neutral levels starting at the volume of 30.
Its very absurd having extra bass at 15 and none at 35
Regards,
Jason
Old Jun 2, 2004 | 05:11 AM
kevin79925's Avatar
i need a system
Old Jun 2, 2004 | 05:34 AM
liloj's Avatar
i like orange juice
Originally posted by kevin79925
i need a system
you slut
Old Jun 2, 2004 | 05:45 AM
kevin79925's Avatar
Originally posted by liloj
you slut
you whore!
Old Jun 2, 2004 | 06:17 AM
liloj's Avatar
i like orange juice
you whore!
lol:P
Old Jun 2, 2004 | 07:48 AM
jiggaman's Avatar
I spend 2 much time here
is that treble/bass neutralizer crap part of the headunit or the factory amp? anybody know?
Old Jun 2, 2004 | 07:49 AM
jiggaman's Avatar
Re: Bass Governer?
any pics of the install?
Old Jun 2, 2004 | 10:37 AM
icey's Avatar
The Young One
I will post pics as soon as its all complete.
Old Jun 2, 2004 | 10:39 AM
icey's Avatar
The Young One
Regards,
Jason
So no i am going to have to throw a new deck in =X
Old Jun 2, 2004 | 10:48 AM
jiggaman's Avatar
are you running the subs off of the stock amp signals?
Old Jun 2, 2004 | 01:14 PM
slo007's Avatar
Master in Science
I have no lack of bass at high volume settings...
Old Jun 2, 2004 | 01:16 PM
icey's Avatar
The Young One
Im running the subs off of the Alpine m1000 amp (1000 watts)
What do you mean by the stock amp signals (Im not audo knowledgable, so...)
Old Jun 2, 2004 | 03:45 PM
jiggaman's Avatar
i mean is the signal for your subs coming off of the rear speakers. i have no drop in bass and either does slo007 and both of us eliminated the stock amp.
Old Jun 2, 2004 | 06:58 PM
icey's Avatar
The Young One
So the radio has no control over the bass limiting, the audio guy is telling me that I cannot bypass the stock amp.
Old Jun 2, 2004 | 07:01 PM
icey's Avatar
The Young One
Where is the stock amp located? Maybe I can find out what's going on myself.
Old Jun 2, 2004 | 10:03 PM
Deelover's Avatar
Jigga and Slo.. Are you guys using the leads to the rear door speakers as the input to your amp? Where are you getting the input to the amp from.
Just picked up some alpine S for the (4) 6.5's and (2) 6x9's. Circuit City has a sale right now, buy a pair get the 2nd half price. Now I'm thinking of amping the 6x9's and one pair of 6.5's
Old Jun 2, 2004 | 10:30 PM
musicbox's Avatar
2004 TSX
For "raw" low level signal, you can...
Old Jun 2, 2004 | 11:57 PM
icey's Avatar
The Young One
so what's going on now is that I have to buy a bew deck with 3 preouts one for fronts one for rears and one for subs, and this is the only way to get the best use of my stuff right?
Old Jun 3, 2004 | 12:26 AM
slo007's Avatar
Master in Science
Of course you can. It's located behind the "not an ash tray". Pull the large center bin with caution not to scratch nearby surfaces (no screws involved) and you'll see the wiring going to the OEM amp just below.
An electrical drawing for the wiring is located somewhere in this forum. Run a search for it.
The crossover for the bass is located in the OEM amp. Bypass the amp and you'll have no problems.
EDIT: The OEM amp takes off all the engine noise from the audio signal that comes from the OEM head unit. You'll need a very good LOC or line driver to get rid of the noise. Several threads have brand/model suggestions. Tuan209 has some good suggestions.
Old Jun 3, 2004 | 12:32 AM
slo007's Avatar
Master in Science
That will make the best audio, but it's not necessary.
No, I pulled the audio signal for my set of front speakers and sub from the HU.
The rear speakers (still stock) run from the OEM amp.
Old Jun 3, 2004 | 12:36 AM
slo007's Avatar
Master in Science
I'm in a good mood:
Old Jun 3, 2004 | 12:41 AM
slo007's Avatar
Master in Science
Found another pic:
Old Jun 3, 2004 | 12:54 AM
slo007's Avatar
Master in Science
Alpine S are good because they fit easily. No cutting required. Good choice!
I used the low-level signal from the HU: lot's of engine noise there, but no ups and downs in frequency present elsewhere. For woofers (6.5), you'll have to bypass the stock amp to amplify it. Otherwise, you'll get distortion since the signal is already amped. A good LOC or line driver will cut the noise away. ** Emphasis on good, not the $20 stuff. **
See the drawing I posted above for the wires you'll need. Make sure the audio wires are in the opposite side of the car as the power leads to the amp you install.
Old Jun 3, 2004 | 01:12 AM
icey's Avatar
The Young One
So you think if i bypass the amp i should have no problems with this bass?
Old Jun 3, 2004 | 08:34 AM
jiggaman's Avatar
wow that's the first time i've seen the stock amp. isn't it cute. haha.
Old Jun 3, 2004 | 10:05 PM
slo007's Avatar
Master in Science
Correct.
Old Jun 3, 2004 | 11:30 PM
icey's Avatar
The Young One
thanx for all the help guys!
Feb 25, 2020 09:57 AM
kb1rl
Sep 30, 2015 10:17 AM
iRaw
ILX
Sep 5, 2015 12:10 AM
