TSX: bass delay with line out converter
Old Aug 24, 2011 | 12:22 AM
shitstorm's Avatar
Just bought an 05 tsx a couple months back and just got around to installing my sub and amp. i used a line out converter to hook up the amp. it seems to work pretty good, the sound is pretty clear and i get a good amount of bass, the only problem i noticed is there seems to be a slight delay in the bass. it hits just a millisecond after it actually does in the song. i was wondering if there was a way to eliminate that? are there some line out converters that work better than others?
Old Nov 22, 2011 | 09:44 PM
ATSX05's Avatar
7th Gear
the reason your having that problem is because the line out your using is attempting to take the full range signal and turn it into a low pass signal and to get a better signal you will need to either run an oem-4 or a signal processor like the rockford 360.2
MrHeeltoe
20
Feb 23, 2023 01:54 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
