TSX: bass delay with line out converter
Just bought an 05 tsx a couple months back and just got around to installing my sub and amp. i used a line out converter to hook up the amp. it seems to work pretty good, the sound is pretty clear and i get a good amount of bass, the only problem i noticed is there seems to be a slight delay in the bass. it hits just a millisecond after it actually does in the song. i was wondering if there was a way to eliminate that? are there some line out converters that work better than others?
the reason your having that problem is because the line out your using is attempting to take the full range signal and turn it into a low pass signal and to get a better signal you will need to either run an oem-4 or a signal processor like the rockford 360.2
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
