CL: HIDs question
Old Nov 14, 2011 | 06:50 PM
MIKE8898's Avatar
Bonki Ehrite!
HIDs question
Im looking at a 6000k DDM kit. my questions are
what is the bulb type?
35 or 55 wattage?
do i need any extra wiring harnesses?
thanks for the help in advance
Old Nov 15, 2011 | 05:54 PM
on1wheel01's Avatar
This belongs in your model specific forum just fyi. 55 watt can put of more heat which can burn up/melt things. And it's always better to use a relay but not necessary.
And asking what bulb,really? Go out to your car and pull one out and find out.
Old Nov 17, 2011 | 06:40 PM
tc5280's Avatar
Flagship Aspec
you will need to cut wires switching ballasts i think, why not just get bulbs? something wrong with your ballasts?
Old Nov 17, 2011 | 10:26 PM
MIKE8898's Avatar
Bonki Ehrite!
ballast on the drivers side died so i am replacing both
Old Nov 17, 2011 | 10:56 PM
jacksonstl03's Avatar
If you use a 55w ballast, you need to upggrade factory harness.
Old Nov 22, 2011 | 09:09 PM
ATSX05's Avatar
7th Gear
its most likely a d2c bulb like most of the newer acuras and there is never a need to upgrade to a 55w bulb do to the fact that 35w applications produce more than enough light coverage and unless you buy a cheap ebay hid kit you dont need to run relays on them due to the fact that it will be plug and play but if you get a blinking or flickering then you would run a resistor and relay harness inline
Old Nov 24, 2011 | 10:36 AM
MIKE8898's Avatar
Bonki Ehrite!
thanks. i already ordered a 35 watt 6000k kit with the raptor ballasts from ddm. and the bulb is a d2r not a d2c
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
