AUX on non nav TSX question
Old Sep 29, 2005 | 09:27 PM
jiggaman's Avatar
I spend 2 much time here
Right now I have nothing hooked up to my AUX, so is it normal that when I push the CD/AUX button twice nothing happens? My concern is that when I hook up the SHOND3 to my AUX that it wont work. Maybe I am just having pre-install paranoia....
Old Sep 29, 2005 | 10:52 PM
KaMLuNg's Avatar
if u have the aux component plugged into the wire, it should switch to aux when u hit the cd button...
maybe diff unit than mine, try hooking in a ipod or something
Old Sep 29, 2005 | 11:06 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Yep that's normal man. When you have one of those SNHOND3 or Blitzsafe adapters hooked up to the AUX input, that's the only time you will see the "CD-C" mode when pressing the CD/AUX button.
Before I got my SNHOND3, mine didn't do anything either when I pressed CD/AUX twice
Old Sep 30, 2005 | 04:45 AM
einsatz's Avatar
I miss my 03 CL-S :(
The SNHOND3 and others emulate a cd changer to make the HU think there's one connected. That's what you need them for. It's more than just a l/r audio signal. If the HU doesn't receive a "signature" signal of a cd changer, it won't go to aux mode.
Old Sep 30, 2005 | 05:43 AM
jiggaman's Avatar
ahhhh, is this a simple install? should i print out instructions from other members for the shop that is doing the work for me?
Old Sep 30, 2005 | 10:15 AM
KaMLuNg's Avatar
isn't it just a simple plug into the back of your stock HU??? i am sure u can diy... just need to pull apart some of the dash... a good weekend project for 2 hours... it took me 20 mins to install.. but i knew what i had to remove...
Old Sep 30, 2005 | 02:04 PM
Tsx536's Avatar
Rep'n Taxbrain.com
It's super easy. Is the shop gonna charge you? You might wanna even do it yourself.
On the TSX, the AUX port is on the bottom of the factory HU. So the only thing you'll need to remove is the storage bin. put a CD/mirror in there, so you can easily see the plug, and then plug it in.
From there, they will just need to plug the output of the Sirius tuner into the SNHOND3
Old Sep 30, 2005 | 02:31 PM
jiggaman's Avatar
they are not charging me... plus i'm having them put the antennae on the drivers side above the windshield instead of the passenger side
that way trees will not cause interference as much...that seems to be when it cuts out, on these new england roads with trees hanging over
BoricuaTL
Apr 8, 2016 01:08 PM
Rocktman1
Sep 19, 2015 05:58 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
