TL: audio help!!!!!!
Old Jun 3, 2010 | 06:41 PM
3.2tec's Avatar
audio help!!!!!!
hi this will be my first post to the forum i just wanted to say hi to all and i need your help i am just starting to do work on the stereo of the car and i want to know if this is possible: it has the stock Bose stereo still, stock head unit and all now it has a sub woofer in the rear deck is it possible to unhook that sub and use those live wires to power a after market sub this will be temporary i haven't tried this yet and i want to know if it will damage anything thanks.
much appreciation
3.2tec
Old Jun 3, 2010 | 08:17 PM
Anachostic's Avatar
If you are disconnecting at the sub, you are post-amp, specifically, post-Bose amp. Bose has a nasty habit of running anything but typical impedance (4 ohms) on their speakers. In my MX-5, the Bose amp runs at .5 ohms. Stupid.
The first point being that you are very likely to mismatch the impedance of the amp and your aftermarket sub, possibly causing damage. If you don't have damage, you probably won't get much sound at all since the Bose amp is not very powerful and is likely at 2 or less ohms.
Old Jun 3, 2010 | 10:31 PM
03tLsNBP's Avatar
MechEng
First of all, welcome to the forum!
i HIGHLY recommend using a dedicated aftermarket amp to power the sub. when i installed my 12" Kicker L7, just for shits and giggles, i did exactly what you are asking. no sound came out of the sub. i now use a 1200W Sony Xplod amp.
Old Jun 3, 2010 | 10:34 PM
mattastick's Avatar
i HIGHLY recommend using a dedicated QUALITY aftermarket amp to power the sub. when i installed my 12" Kicker L7, just for shits and giggles, i did exactly what you are asking. no sound came out of the sub. i now use a 1200W Sony Xplod amp.
Fixed, and you should take my advise as well...
Old Jun 4, 2010 | 02:41 PM
oeasy's Avatar
yes u can jus use this .... http://www.sonicelectronix.com/item_...OEM-HON20.html
Old Jun 5, 2010 | 07:32 PM
Jimmay's Avatar
Originally Posted by oeasy
I believe this is to ADD an aftermarket amp. The OP wanted to power a subwoofer with his factory Bose unit. The factory unit probably has something around 200 watts...and i believe thats peak. You wouldnt be able to power a subwoofer(at least very well) with that, and as other people mentioned impedance issues.
Old Jun 6, 2010 | 12:03 AM
on1wheel01's Avatar
Yea but quality and sony products should never be in the same sentence especially their amps so I think thats why he worded it the way he did lol. Yea and just get a nice mono amp. Hell they can be had brand new for $100, check out hifonics or audiopipe. Good low budget amps.
Old Jun 11, 2010 | 11:27 PM
FR3SH_TL01's Avatar
6th Gear
I would definetly not recomend you to do that remember that output for the stock sub in the rear deck was made for that stock bose sub no more watts are gonna come out from that radio just go get an aftermarket amp you will be better off and would get greater sound.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ValdezQ26
Oct 1, 2015 04:48 PM
navtool.com
Sep 25, 2015 05:15 PM
