ATTN : SilverKnight or other audio gurus
is Pretty Much a Moron
1 Post
"Skyline" SAN FRANCISCO CD70 RECEIVER
Innovation 2001 Design & Engineering Showcase Honoree
KEY FEATURES
STANDARD FEATURES
180W Hi-Power KeyCard™ CD DigiCeiver™ with CD Changer Control
45 Watts (Max.) x 4-Ch
4-Ch Low Impedance Preamp Output @ 5V w/Sub Output
DSA Digital Sound Adjustment / Automatic Self Adjusting EQ
DNC Dynamic Noise Covering / Combats Long Duration Ambient Noise
Calibrated Microphone Included
Internal Pink Noise Generator for Sound Measurements
User Adjustable 7-Band Digital EQ with 3 Memory Banks
Selectable EQ Presets for Different Music Types
DigiCeiver Codem D All-Digital Tuner including RDS & Sharx™ Adaptive IF Switching
Improved Multicolor Dot Matrix Display with Animation & 2-Tone Faceplate
Selectable European & USA Tuning Modes
24 FM / 12 AM Presets Including 6 FM / 6 AM Travel Store Presets
2-Tone DIN Flip Panel Faceplate with Stealth Type KeyCard Holder
Softkey Design Controls Improve Ease of Use
RDS Radio Data System with Station Call Letter Display
Station Naming, Radio Text & Preset List
Digitally Processed AM Interference Suppression
12/24 Hour Clock
Blaupunkt's Exclusive BP-1 CD Deck with 3-Beam Holographic Laser Pickup & 1-Bit/32X Oversampling Digital Filter
DMS plus CD Naming, CD List, Scan, Mix, Repeat, Peak Level Meters & Last Position Memory
Menu Options including: 6-loudness Levels, Adj. Scan Scan Time, 3 Hi-Cut Levels,
Loc/ DX Level Selection, STM, Clock, & Aux-In for MP3 / MD / DVD
High-Pass and Low-Pass with Selectable Slopes
Selectable Outboard Amplifier Turn-On Delay
Subwoofer Output with selectable freq @ 80/100 Hz
Includes Handheld RC 10H Infrared Remote - Thummer III or RC09 (both optional)
Defeatable Internal Amplifier
Controls Optional CDC A08 & IDC A09 CD Changers
San Francisco CD70 STEP UP FEATURES
180W High-Power KeyCard™ CD DigiCeiver™ with CD Changer Control & Remote
Includes all the benefits of the Hamburg CD70 plus:
DSA Digital Sound Adjustment / Automatic Self-Adjusting EQ
DNC Dynamic Noise Covering / Combats Long-Duration Ambient Noise
Automatic Pink-Noise Generator for Sound Measurements
User Adjustable 7-Band Digital EQ with 3-Memory Banks
Handheld RC 10H Infrared Remote Included
36 Station Presets
Station Naming
Radio Text
Preset List & CD List
5-Volt Level Preamp Output
Subwoofer Output with Selectable Freqs @ 80/100 Hz
Longer Duration Amp Turn-On Delays for Upgrade Flexibility (0 to 8 seconds)
Defeatable Internal Amplifier via Menu
[QUOTE]
So I could keep the stock speakers and amp, and just put this in and still maintain all of the above features? What aabout the stock steering wheel audio controls? Sorry, I am a novice about car audio.
KEY FEATURES
STANDARD FEATURES
12/24 Hour Clock
36 Station Presets
Station Naming
Radio Text
[QUOTE]
Retired. Not available.
Due to lack of info on stock amp and speakers, I cannot say anything for sure. I could say "YES" but keep in mind that you will not get any sound quality or volumn improvement. Here are the reasons.
Since Bose wrote to Ronnie738 saying the stock amp put out 25w per channel (assumed Max or Peak output), besides, I really doubt the amp is capable of receiving high voltage input. Therefore, It would not do you any good if you keep the stock amp. About stock speakers, from what I saw (made of papercone) and hear (weird impedance), I dont see the point of keeping them.
That were the reason why I said "you are heading in the wrong direction on a one-way street." since most ppl replace stock amp+speakers and keep the stock HU.
Hope it helps. Good luck.
What he said!
I have the stock HU and ditched the speakers and amp...and now its sweet!
Guest
Posts: n/a
Allerick B.
Originally posted by CL_Terminator
Being the car audio prodigy that I am, I would persume to say that the Bose amp more than likely puts out 25 watts per channel RMS, not peak or max. If your system is similar to they system in my Legend then I am almost 99% certain. But yes they are made of papercone, and yes they have, not necessary weird, but low impedances. But they Bose system is a very high quality system. They components sets they use are usally the weakest part of the system. The amps and head units are top of the line. Your amp will accept high level inputs. Thats how its is run from your headunit. Your head unit acts as a pre-amp for the main bose amp, which is usally hidden behind the rear passenger seat. The way the system is ran actually makes it very convenient to do upgrades. But no stereo shop that knows what they the are doing will let you know that. But having worked on my own personally, I'm speaking from experience. I would be more than happy to make some suggestions that I'm positive would help you to achieve the type of sound that you want.
Allerick B.
Allerick B.
EDIT: It seems to me that you are a BOSE employee or a BOSE fan. Well, I'll post the stock amp pic. I hope you can tell that worthless 1lb piece of junk BLOSE amp puts out 25w x 4 rms
9th Gear
Bose.
I just got my '99 Cl and I love the bose system. I've had alot of cars and this system is by far better than any i've had in the past. Also, I highly doubt bose would put an amp that peaks at 25w.
And the size of an amp really doesn't matter how many watts it can put out. It does in a way, but it depends on how your running it. I used to have an autotek stealth xs-1500.1 which isn't a very big amp, but it did 1500w (bench tested at 2001w), people were really suprised when I told them how many watts I was pushing out of a small sized amp.
Shay
Shay
Bagged hybrid
I've tried many things with my stereo and I can tell you that our 25Wx4 RMS or peak amp is not very high quality. Sure, small amps can put out a lot of power, but what about weight? This thing weights like 2lbs and most of it is probably the metal casing! Sure, the HU is a fat deck w/ indash 6, but to get some good sounding tunes, you gotta gut it all out. IMHO of course.
Find beauty in dissonance
I don't think anyone has run low level inputs from an aftermarket head unit to the stock amp. But, someone has to be first.
The head unit would be the last thing I would replace on my system. Replace the amp and speakers first.
BTW: that head unit looks nice!
Originally posted by Bluto
The headunit puts out 500 mV. Not sure how many watts. But, that is low level. Run high level inputs to the stock amp and it won't last very long.
I have had this hooked up for 2 months, use it all the time, and have no problems whatsoever. Sound couldn't be cleaner.
Guest
Posts: n/a
From what you post, I'm pretty sure you are not familiar with the system in our CLs. The head unit is not Bose's but rather Pioneer's. I know this because I saw the label on the unit itself. With all the BS from Bose (you can verify it on their website FAQs page), I doubt the number they gave one of our members is RMS. I dont know what you got in your Legend nor can I argue with you about that system but I know for sure what are in my CL and how "good" they are.
Allerick B.
Guest
Posts: n/a
Re: Bose.
Shay
Shay
Guest
Posts: n/a
Guest
Posts: n/a
I agree with you. Size does not 100% (yet an important factor) contribute to the output power but weight does. There is no way (at least for now) you can get a high performance amp that is light and small.
Allerick B.
I disagree with you. 90% of the weight is most amplifiers is heatsink. The actually components are light weights. What exactly to you consider to be "high performance?" 'Cause high performance doesn't not necessary mean high power. High performances stereos are based more of thier quality of sound and components rather than the rated output of the amplifier.
Allerick B.
Allerick B.
I dont know about you, but if I hear someone says "performance" car, I would think of speed, how fast the car is not how luxury it is. If I talk about "high performance" amps, then I talk about output power not sound quality. I believe we were talking about the output wattage of the Bose amp, right? :P
9th Gear
FYI, i'm not trying to prove my point by lying or anything, but my autotek was made to be flush mounted, so it had a huge heat sink. It was all chrome but it still didn't have much weight behind it.
Gosh I miss that amp.
Guest
Posts: n/a
Exactly, the heat sink contributes most of the amp's weight. the more power an amp puts out, the more heat is generated => bigger heat sink => more weight. Therefore, I dont see how a 1lb amp would put out 25w x 4 rms.
Allerick B.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
