Trunk Noise
Old Feb 4, 2002 | 12:16 PM
Rudebwoy's Avatar
Question Trunk Noise
[B] Does anyone who has aftermarket subs have any trouble with the trunk vibration? From the outside does it rattle a lot? If so what can be done to prevent this?
Old Feb 4, 2002 | 12:37 PM
I have that too....when i have my bass turned up. Best way to take care of it though is to dynamat the trunk..i think. And make sure that its not your liscnese plate rattleing.
Old Feb 4, 2002 | 01:24 PM
StreetEffectz's Avatar
Dynamat is not the answer...it may help "quiet" it down, but it WILL NOT eliminate it. You need to find out what's rattling and stiffen it up.
Look at it like this...rattling, or vibration, is cause from parts "moving". If you put dynamat on it, it's still going to move. I can tell you that most of the noise of coming from the top part of the trunk, behind the carpeted piece. You need to remove it, and stuff foam or something in there, along with securing the trunk release line to the car better...that alone vibrates like crazy against the metal of the car.
Also, the license plate...put weatherstrip behind it, and add two screws in the bottom two holes
Old Feb 4, 2002 | 01:38 PM
Austin519's Avatar
Streeteffectz:
"Also, the license plate...put weatherstrip behind it, and add two screws in the bottom two holes"
Ha that'd suck for those of us without two holes on the bottom...drill into the car??
Rudebwoy:
The best way to combat this problem is just to port subwoofer boxes into the cabin through the rear deck or rear wall...that way your trunk doesn't act as an enclosure and you won't have the compression and decompression you get when you don't port the box.
Austin519
Old Feb 4, 2002 | 11:13 PM
LOL, yeah, tap two more holes I do it all the time
Old Feb 8, 2002 | 01:11 AM
Mr.T's Avatar
The spolier rattles too just for ppls to know.
Mr.T
Old Feb 8, 2002 | 01:17 AM
Austin519's Avatar
Streetz:
Ha yeah this is the other people's money other people's cars thing we talked about earlier Not drilling any holes in my TLS
Austin519
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
