Amps
Old Feb 23, 2001 | 10:01 PM
Henry's Avatar
Post Amps
I need some help, I have an '01 Acura CL-S and I just wired an amp to the system. I cut the wiring harness at the rear Bose amplifier and soldered all the correct wires to the correct amp wires. I then ran 4 gauge power wire and grounded the amplifier.
I soldered a pair of RCA plugs to each of the pair of audio outs from the head unit. I soldered the positive to the center wire of the RCA and the negative to the ground of the RCA.
The problem is that I have a slight alternator whine when the system is on. I believe it's coming from the head unit/RCA plugs because the whine is only there when the head unit has sound coming out. When the volume is all the way down there is no whine/sound. But whenever I turn the knob to one notch I get whine. Any help I'd appreciate it. Thanks.
Old Feb 24, 2001 | 01:34 AM
AcuraTL's Avatar
OG
Post
Try to get a ground loop isolator. You can get it from Radio Shack for like $15.
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. Matriz ion yellow fog light bulbs(courtesy of Snook). More to come later......
Acura-MDX.com Forum Moderator
Old Feb 24, 2001 | 04:20 AM
Henry's Avatar
Post
I don't think the ground loop isolator would help. The whine is only there when there is signal from the head unit. If the volume is turned all the way down there is no whine. If it was a ground loop problem wouldn't there be the whine whenever the amplifier was powered up?
Old Feb 24, 2001 | 02:17 PM
mr tl's Avatar
Post
i dont understand that. you soldered rcas to speaker wires? your not supposed to do that
Old Feb 24, 2001 | 03:57 PM
96TL's Avatar
Ex-Mod
Post
You need to buy one of those small boxes that tap into the speaker leads and it has RCA inputs on it. Sorry, I forgot what its called.
Old Feb 24, 2001 | 06:15 PM
Lightbulb
That's right 96TL - it's called a Line Output converter. I You can use a 2-channel converter connected to the rear speaker leads from the head unit to get full range audio. Plug your RCAs into the converter and to your amps.
Old Feb 24, 2001 | 06:19 PM
mr tl's Avatar
Post
thanks for the help TLDADDY
Old Feb 25, 2001 | 04:16 AM
Henry's Avatar
Post
I didn't solder the RCAs to the speaker outputs, I soldered them to the outputs from the head unit. The head unit's output is strong enough that I need to turn my gains on my amps almost all the way down. I tried to use line converters but they lowered the output too much. If I tried to tap in after the factory amp I could have used the converters. Any help would be appreciated.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
