amp wiring question
Old May 1, 2002 | 12:31 AM
is300&3.2tl's Avatar
Question amp wiring question
jl 500/1 amp, 2-10" pioneer tw-s2541c subs
when tapping the input to the stock amp for signal and connecting rcas to that, which wires do u tap? do i cut the brown wire and tap the 2 in there? or do i tap the yellow and purple wires after the connector pin that runs into the amp?
so far i already got the amp on. so the power, ground, and remote are ok.
Old May 1, 2002 | 01:57 PM
Brewboy's Avatar
Use the two wires inside the brown sheath before the connector. BTW, the two wires are connected to (1) RCA for a mono input to an amp.
Old May 1, 2002 | 04:23 PM
i got it!!
the two wires i tapped have to go into 1 RCA. that is, theres a positive and negative, so they connect onto one cable instead of two. thanks for your help.
BoricuaTL
Apr 8, 2016 01:08 PM
Type S Zero
Feb 17, 2016 02:37 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
datadr
Sep 12, 2015 09:12 PM
alan_rich
Sep 7, 2015 11:08 PM
