Amp Wire Kit???
Amp Wire Kit???
If I'm going to install 2 aftermarket amps to the Bose HU (bypassing the EQ of course) to power the 4 door replacement speakers - do I need to use a amp wire kit for EACH amp??
Depends on how powerful the amps are. I have a JL 300/2 and a JL 500/1 and I ran 4 awg from the battery and into a distrobution block. Then ran 8 awg into each amp. I use 8 awg ground from each amp ground at the same point. So, I am running around 800 watts. If you are below 500 total, you could probably run 8 awg from the battery but, more is always better than not enough.
ChairmanMaoSaysRTFM
i agree with AcuraX2, for cleanliness sake you may want to run a larger gauge from the battery to the trunk or whereever into a distribution block and then the smaller gauges. if youre running obscene numbers of watts, then double runs of wire may be in order.
You could get away with 8 awg from the battery and then just split it and run 8 awg to each amp. I would consider going ahead and running 4 awg. More is better and if you ever want bigger amps, you already have the wire.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
SUPRMN84
10-07-2015 09:46 PM
4drviper
09-23-2015 09:00 PM
