Amp Question
Old Jun 11, 2003 | 08:51 AM
d3rk's Avatar
Become Hypnotized
Amp Question
Alright I can't get my Amp to turn on, I haven't hidden my wire or anything, so everything is easily accessible... I have a 4 gauge power wire with an 80 amp in line fuse running straight to the Amp, I have it grounded and I have the remote wire going to the hot wire to my driver side rear 6x9.....All fuses are intact...If anyone can help me plz do so...Thank you for al your help in advanced...
Thanks Again,
Derek
Old Jun 11, 2003 | 09:49 AM
AcuraX2's Avatar
I am a little confused on the remote wire. Do you have it hooked up to your speaker? If so, that will not work. The remote has to be hooked up to a switched power wire that either comes on when the car comes on or only when the radio comes on. Just to check your amp, you can hook the remote up to the amps power wire to make sure the amp works. If I read the post wrong, I apologize. Straighten me out if I did.
Old Jun 11, 2003 | 09:58 AM
d3rk's Avatar
Become Hypnotized
the remote wire is hooked up to jus the hot wire off of the rear 6x9
but I will go try the remote wire to the power and see if that works real quick
Old Jun 11, 2003 | 10:11 AM
d3rk's Avatar
Become Hypnotized
hey AcuraX2 that didn't work, I think I need a better ground...I only dun a quick run of it being I'm at work and all, I took a smoke break and checked it out...Thx for ur help, if u have any good ideas to ground please tell me, I can't find any large screw in the trunk...my car is real ghetto rite now, I need to hide all the wires, but first I would like to get it working...Thanks for all your help...
Old Jun 11, 2003 | 11:15 AM
AcuraX2's Avatar
You need to get a good ground for sure. The paint needs to be scrapped away and even sanded down to the bare metal would be best. I use ring terminals and drill a small hole into the car. Then run a screw thru the ring terminal and into the hole. Ground is very, very important. Also, the best place for remote is at the head unit but, if you do not mind the amp coming on whenever the car is on, you can use a wire that is only on when the car is on.
Old Jun 11, 2003 | 11:21 AM
d3rk's Avatar
Become Hypnotized
Couldn't I jus put in a toggle switch between a fuse and the remote wire? and jus kill the power when I want?
Old Jun 11, 2003 | 11:24 AM
d3rk's Avatar
Become Hypnotized
If so, what size Fuse should I use and should I jus run it from the fuse box?
Old Jun 11, 2003 | 12:27 PM
AcuraX2's Avatar
You could do it that way but, it would be kind of a waste. If you are tapping the fuse box just tap a wire that turns on with the car and you are done. The fuse size really would not matter much. The remote pulls a very small amount of current. Just enough to tell the amp to turn on.
Old Jun 12, 2003 | 09:04 AM
d3rk's Avatar
Become Hypnotized
K, thx AcuraX2... I got it all working last nite, I told these gurlz to meet me at 2:30 yesterday and they didn't show up til 3:30. So, I had plenty of time to troubleshoot everything and It alll worked fine...I appreciate all ur help...
Old Jun 12, 2003 | 09:23 AM
AcuraX2's Avatar
No problem at all. Glad I could help in any way.
Old Jun 18, 2003 | 12:00 AM
SwampGas's Avatar
/etc/car
The remote wire for the stock sub didn't provide my amp with enough juice to kick the relay on (even with the stock amp totally removed), so I had to run a wire up to the fuse box and tap a switched line.
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
