amp instal
Old Nov 20, 2000 | 05:43 PM
Guest
Guest
Posts: n/a
Question amp instal
can anyone help and tell me where and how to get to that sub stock amp. I have been told it is behind the rear seat, so how do you get to it. And can you get all the signal you need from the stock amp to add on the aftermarket one. As far as power and signal??
Thanks in advance, Omar
Old Nov 20, 2000 | 09:59 PM
mr tl's Avatar
Post
you have to take out the rear seats to get to it. you can only take out the back part seat, but you might risk scratching the bottom.
you can get the sub signal from there, but not the door speakers. the only power wire you get from there is the remote wire
Old Nov 20, 2000 | 10:26 PM
preludeshfan's Avatar
Post
it is located on the right side behind the seat back. you need to remove the floor from the trunk and pop 2 plastic clips out. and remove the carpeted cover that goes around the shock tower and along behind the seat back. the amp is is big as your hand. the remote wire is blue after it passes through the connector on its way to the amp. there is also signal wires that are twisted and covered in a brown sheath. the turnon lead is a very low current capacity. it would not turn on my amp. you may have to boost the current on the turn on wire by installing a transistor and hooking the base of the transistor to the turn on wire, the emitter to the amp and the collector to 12 volts. i cant remember if you use a NPN or PNP transistor.
formerly 98 prelude type SH
Currently 2001 Acura 3.2 TL With Navigation Black/Ebony
Old Nov 21, 2000 | 12:15 AM
mr tl's Avatar
Post
ummm, remote wire is orange
its able to power up all 3 of my amps w/o any direct modifications
Old Nov 21, 2000 | 10:03 AM
Guest
Guest
Posts: n/a
Thumbs up
Thanks a bunch for the info. Really had no desire to take this to a shop. I really prefer to do this on my own, and this was 50% of the worry. Thanks again I will let you know how it goes and hopefully get some pics in!!
Old Nov 21, 2000 | 10:38 AM
Guest
Guest
Posts: n/a
Thumbs up
AndrewS
19
Mar 14, 2024 06:59 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
