All New Speakers in the 03 CLS6 (PIX)
I've been out of work for a while, and have a good amount of time on my hands, so I figured I would contribute after all the valuable information I have received in the past lurking.
Here is a project i finished in the fall, replacing all of my stock speakers with aftermarket ones.
In the front doors I put in CDT 6.5 components, which were a headache to get in. I had to increase the diameter of the opening in the sheet metal to allow for the basket of the speaker to fit, even with a 3/4" MDF spacer!! To do this, I put a stone grinding bit on my drill, and put some elbow grease into it. Mounted it using bolts from Lowes, and lock washers. Sounds good, runs off the stock amp. I also modified the sail panel where the tweeter is located, and put the new tweeter in the stock location. (NO Pics Sorry)
In the rear deck, I was able to put CDT CL-69 6x9's in the stock location, retaining the stock speaker covers, and avoiding the torsion bars in the trunk(Barely!). To do this I bought a 1" spacer and cut away some of the interior fiberboard to incorporate the spacer. Mounted it using 1 3/4" bolts and corresponding nuts from Lowes. Sound Great! even on the stock amp.
If you have any questions concerns or comments, ask away!
PICS:
PICS:
Looks good man But I like the stock speakers its just there not very loud and have no bass at all ares those ones louder and I think? for me the rear speakers would be to close it Would rattle from my subs
But it looks good and now I know all the work im in for when I decide to upgrade my speakers!!
I had a 95 maxima with a bose system and hooked speakers up to it sounded like because speakers were running like 2 ohms and systems amp was .5-1 ohm I looked up stock specs on info section but it didnt say how many ohms our system was running do u guys know
I want to do this mod pretty soon not loud enough
My last car had 2 10 2 12 1 18 4 6x9s and tweeter and amps
I think im goin def
I think im goin def
I think im goin def
I think im goin def
My system does in fact get pretty loud. Not insanly loud with the lowered sensitivity of the aftermarkets, but with the tweeters goin, any louder would be to shrill, and drowning.
Two alternators Two batteries I got two tens in my acura now friends say it sounds nice but I want it louder after my last car I like nice sound but every once in a while i like to crank so I have trouble breathing but i always have each pair of subs on switches so I can turn them off and on when I want to show up some punk with a civic they really go crazy when your trunk pops from the bass
MrFluffy check the FAQ on this page (AV forum) https://acurazine.com/forums/forumdisplay.php?f=22
if you want to be sure, but I think it's in the .5-1 ohm range too
i just got my stock radio replaced with an aftermarket pioneer head unit and i have 2 12 sub's in the trunk.. but when i turn my car on and listen to the radio.. there is a buzzing sound. the guys at fry's told me to get A/C sound filters for my radio and i did.. but i still hear the buzzing noise. anybody know what i can do to fix this?
It's because the HU is putting out signal for normal speakers, while our Bose ones run on a different impedance range... there is some kind of converter thing you can get... go talk to a car audio guru somewhere...
You just wire it inline with the headunit harness. There are two knobs for gain, front and rear. You can adjust as if it were an amp.
Obviously if you are running aftermarket speakers and an aftermarket amp, you don't need this.
I' going crazy with mine. My Memphis components are too thick for the front and my memphis 6x9'S magnet is too thick. I have problems with my trunk lid torsion bars. I just had this speaker from my last car and don't want to buy new ones. I don't think I can install any 6x9's in the back that can withstand the 100 wrms watts per channel that I'm gonna send them. Any suggestions?????????????
kb1rl
09-30-2015 10:17 AM
polish_pat
09-25-2015 12:24 PM
4drviper
09-23-2015 09:00 PM
rboller
09-23-2015 02:49 PM
