Aftermarket Headunit with stock amp/sub help
Old Jan 25, 2007 | 05:02 AM
ealimov's Avatar
I got a jvc headunit installed, with the speakers still run off the bose amp, but the sub is not working. i really want to get the sub running again, but dont know how to do it from behind the headunit (dont want to run rca's from the back seat). do i need a line-in converter, and if yes, does the line output converter work backwards? any ideas appreciated.... BTW its an 03 tl
Old Feb 15, 2007 | 04:14 PM
ealimov's Avatar
Anyone at All?
Old Feb 21, 2007 | 02:55 PM
TTU-TL's Avatar
Smooth and Elegant
I have the same problem, I've tried everything to get the stock sub hooked up with no results, I"m just gonna buy a cheap amp and run RCA's and do it the easy way, keep it simple. Cause that sub sure sounded good, I miss my baby....
Old Feb 22, 2007 | 11:25 AM
dreem1er's Avatar
deal with it
there is no way to connect once you change your HU........if you want to keep it you have to buy an amp and wire it up the same way you wire any aftermarket sub.......
Old Feb 22, 2007 | 11:49 AM
uncald4's Avatar
Former Sponsor
This is not accurate. Sorry dreem1er. You can wire up the factory subwoofer amp right to the subwoofer preout on your new deck. That way your subwoofer control on your JVC will control the level of the factory BOSE sub. Works awesome. Instructions are in the DIY section at the top of the "Audio/Video" forum. Please read that first. If you still have any other questions please let me know.
Old Feb 22, 2007 | 04:05 PM
dreem1er's Avatar
deal with it
i didn't know that could be done........i never seen that done on any car.......and when i asked the shop i go to if there was any way to connect it they told me no.....but then again the installer that said no was fired awhile ago.......but whatever if the factory sub can be wired from an aftermarket HU then i gonna do that this weekend........i do kind of miss the damn thing.........thanks for catching my mistake..........sorry about the misinformation
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
rangomango
California
Sep 24, 2015 05:47 PM
