CL: adding aux to factory non-navi radio
Old Jan 21, 2014 | 09:20 PM
03-6/6's Avatar
M90booosted
found this unit on ebay :
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=251100132151&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
however, it says it will not work with factory indash 6 disc changers. i understand that would not work with external as the plug it needs would be filled.
I want to do the indash tablet mod and i want a really clean install. planning on using this to connect tablet to radio instead of using a tape adapter. lol.
Old Jan 24, 2014 | 02:06 PM
ghowell6's Avatar
5th Gear
I've had a great experience with GTA Car kits. You can still use the factory CD changer in your stock deck- you just press the CD button one more time to access the external changer port. http://www.gtacarkits.com/acura_cl_2...03_car_kit.php
It has an iPod cable and a 3.5mm line-in adapter, which sounds like it will work well for your tablet. If you have any questions about installing it or routing cables, they have an installation video as well. My only recommendation is to not drill a hole in the console- I routed it through a hole in between the center console and the cup holder. I can post a picture later that shows the routing.
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
lanechanger
Oct 13, 2015 10:56 AM
