adding 3rd amp need opinions?
Old Jan 18, 2004 | 04:07 PM
kman156's Avatar
Thumbs up adding 3rd amp need opinions?
doing a kick panel install , and need amp space! there's no room left on top of my box!. mounted it temporarily against my box in the cabin to see if it would fit behind the back seat? still haven't checked to see if the seat will fit without cutting out some padding. my main concern is the amp overheating!!! any ideas? thanks!
Old Jan 18, 2004 | 04:08 PM
kman156's Avatar
closeup amp
shot
Old Jan 18, 2004 | 04:16 PM
njtls's Avatar
big fan of ducktape eh?....maybe you could cut a hole on the side where you have that tunel for the the pass throguh and add a fan if you worried about over heating
Old Jan 18, 2004 | 09:15 PM
shawhite's Avatar
personally i would put all my amps together in maybe a false floor in the trunk... right above the spare tire..
Old Jan 19, 2004 | 12:50 AM
kman156's Avatar
trunk not an option
i already have my trunk worked. i think i figured out since i already have a stinger fan on the top of the box cooling another amp, and the center armrest is a screened enclosure which air/sound freely passes through since i have my subs aimed in to the cabin. i can drill multiple vent holes in the wood the amp rests against, and some more to the left of the amp in the wood. that will provide enough air flow to keep it
Old Jan 19, 2004 | 11:57 AM
StreetEffectz's Avatar
I'd personally say not to put it there. Overheating will most likely be an issue just because of the confined area you're trying to squeeze it into with the seat right up against it.
I do have an idea however If you're not using the factory sub anymore, and it appears that your box is vented directly into the cabin via the ski pass, why not mount the amp of the rear deck and make a nice trim (cover) for it, so you can see it :wow:
Old Jan 19, 2004 | 01:23 PM
njtls's Avatar
^ oh hes good ....maybe some neon and plexiglass too
Old Jan 19, 2004 | 06:26 PM
kman156's Avatar
Thumbs up you don't know how good!
great idea! :bowdown: thanks ron! that's where i was gonna put the varads. when is blue in stock? they have to be blue to match the crystals!
4drviper
Apr 23, 2025 07:13 PM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
