Added Alpine SPS 171A's to my 06 TSX
I had installed the Alpine component SPS 171A speakers in my front doors and dash in my 06 TSX.
They really make a difference. Really brings out the vocals and high notes. The bass sounds a little tighter as well.
A great sound improvement for not a lot of money. I had the work done for me so I don't have a lot of technical details. I know that they used the crossovers in the TSX and they had to add one spacer.
I really like the improvement.
Excited
Excited
Excited
Excited
Was the volume the same or louder?
The difference in sound is very noticeable. Although I didn't mind the stock speakers I felt that the vocals sounded like they were more in the background. The Alpines really bring forth the vocals and they are out fromt where they should be. The new speakers make the music sound more real and the highs are really crisp.
They cost me $189 Cdn and were a very good investment.
I notice that your age is similar to mine. I suspect that you may be like me where I don't need the neighbours down the block to hear the bass, but rather to hear good sound reproduction. The Alpines really help to achieve that.
Excited
So, these are powered by the OEM amp and you just swapped the speakers? Do you know if the installer used the OEM tweeter signal to your new Alpine tweeters or if they used the front door signal and the Alpine crossover?
The SPS 171A's are a little more efficient than stock speakers. I had to adjust the fader to bias the rear speakers a little more to create a better balance.
Excited
Excited
Are there matching woofers for these speakers?
I'm pretty sure that he used the OEM tweeter signal as he told me he did not use the Alpine crossovers.
Excited
Originally Posted by Spoon
Preferences are preferences, but they are not more efficient. I used to run the 171A's and off the stock amp, and there was a volume loss. Overall quality was better to be sure, but they are not more efficient that the stock speakers.
They do sound better that is for sure.
Did you do anythihng else?
Excited
Originally Posted by Tsx536
Excited, they're just subwoofers.
However, some folks have replaced the rear deck 6x9s with coaxials. They only get low frequency signals so there is nothing for the tweeter to play.
Excited,
So you just replaced the front doors and dash tweeters, correct?
Aren't there also 6.5" (or whatever the same size is) speakers in the rear doors? Did you make a decision not to replace those or are you considering it for another time?
One of my many projects I hope to do soon will be to replace all the door speakers and tweeters. I believe I will go with the same products you did due to correct fitment, and compromise between quality and cost. I am very glad to see your positive write-up of them. BTW, do you know if your installer used the Alpine spacers that came with it or if he had to fabricate some?
I believe I will be replacing all 4 door speakers and the dash tweeters. After that, I'll disconnect the rear 6x9 woofers in favor of a 10" trunk subwoofer. I've got many, many parts on order now and far too little time to do everything. I hope to post pics and experiences as I go with the audio project.
Originally Posted by Reach
Excited,
I believe that they used the Alpine spacers. He made the spacer thing sound pretty simple so I don't think that they fabricated anything. I did speak to them today but I will talk to them again tomorrow to confirm.
When I told him that some people were interested in improving the rear speakers he said that it would best to add an additional amp and sub woofers.
When I mentioned earlier that I talked to the audio guy from FX -Audio it was because he called me to follow up to make sure everything was okay and to see if I still liked the speakers. I thought that was pretty good of him.
Excited
Excited
Jul 16, 2017 07:33 AM
